- P/N Request or ETKA screen shot: ATW Oil pump and assoc parts
- Has anyone fixed a stuck open sunroof? If so...
- What is the B5 forum's consensus on the B7?
- My trip computer keeps telling me a headlight bulb is out, but it's not...
- what do you think of this oil catch can / separator?
- Anyone reroute there diverter valve vacuum line to the front of the intake mani.?
- think I may be dumping the a4 at last
- <sigh> I just can't get my 60' times under 2.00. 14.283@95.92MPH. Beautiful weather in NJ
- vag-com question
- Looking for a diagram....How many check valves on the AEB?
- OK, reading what i wrote how could you not blame me...but....
- will the stupidity never end... sigh... went to start the car
- Weird throttle cut while coasting in neutral?
- Loose Rear Wheels - 98 A4 1.8 FWD
- any experience with eurospec performance rods?
- EFU install completed earlier today. Still waiting for a different style oil temp sender...
- It's plagued me all day, quinn even said im obsessed with that post
- Some guy flagged me down at TGIFridays just now...and complimented my car....he thought...
- I (might) promise i won't start any more threads today.. just a quickie question
- Not Audi but close, cousin VW New Beetle. Thought i share
- So i am really upset that i have the APR intercooler
- Weekend Mod/Mait. Thread
- MAF? o2 sensors?
- could be a fun sleeper for someone... 99.5 1.8tqm
- Feeler: Selling my car...:(
- Widebody Day 7 = How to shave a turn signal...
- Engine not starting
- VAG-COM cannot communicate with ABS system....what is most likely cause?
- trifecta?
- BAHAHAH Rally this is kick a$$ It's my new desktop.. thanks man :D
- alright...now with pictures (i meant to add this to the post below)
- Question for 1.8t guru's ... plus all the other random know it alls :)
- need to change my fan switch 2.8l, any ideas in how to this "SMARTER"
- ESP and ABS lights
- trouble programmin my remote key
- Figured it out.
- Help! Speedometer/Odometer still not working after I installed a new VSS
- Um krissy hansen.. did j00 get that last email at that other address that you gaves me?!
- Just ordered K04..... Not a bad price IMO!
- I need to have my front bumber re-painted & the rest of the car detailed - which to do first?
- T28 running issue: bucking at about 12+ psi. Causes?
- Is there anywhere to pass lines from engine bay into cabin other than ECU box?
- read the valve cover gasket write up. Quick question
- Rear brake bolt question
- Anybody in State College, PA area with VAG-COM?
- Out with the PC16 programming, BT programming on the way...
- instrument cluster question
- MICA!
- Curse you, Mr. Bentley. (Tailshaft seal replacement)
- Help, need new ABS speed sensors and tone ring
- sunroof cover hard to slide back and forth, why is this?
- Any chance someone has a stock passenger side lower?
- WTF Quattro?? I just spun my car when I REALLY shouldnt have....
- Tickets
- oooo hehe what i have been up too!
- Rear Strut
- if i get a new trunk lid, can i just paint the lid? or does it need to be blended in?
- random water
- Starting.. wheres day 6?
- Just picked up a used 97 2.8
- Audi A4 check engine light and airbag light do not illuminate with key on HELP?
- C-pillars showing signs of wetness
- Place to buy secondary air injection solenoids, or P/Ns? Still haven't replaced...
- I could make love with this car... (Audi lovers dont look)
- Need help finding hood for my 98 A4 1.8t
- New wheels are here in 5 days!!! :)D :D:D:D::DD: =) i will lub them soo much
- Joey, did the turbo come?
- Looking for some transmission parts
- How do I raise the sagging knee bolster to the left of the steering column?
- 1997 Audi A4
- Does long Island, NY require snow tires in the winter or all season is sufficient?
- Those with GT25 + Mika Tune, would you do it again?
- EFU install part 1...
- Any opinions on how this software would work with my T28 kit? Upsolute GT28r eliminator tune:
- Whats the deal with H&R coilovers? Why is everyone hyping up the S4 H&R's
- Lets sort out my central locking issues.
- Is my car a 99 or 99.5? How do you know?
- NOOOOOO! First signs of cluster pox this morning...
- Anyone ever change their (edit- Front) passenger side drive axle seal on an Auto tranny...
- Running very rich... a few questions.
- WooT! Engine is back from machine shop.....
- Two choices concerning this automatic engine: What say you all?
- Just when I thought I was done... :/
- Is there a 'spacer' in between an automatic flywheel and the crank in a 1.8T?
- This is the most beautiful S4 I've ever seen!
- HID Headlight ? again. Anyone know how these are?
- Running BT and having power hesitation during cold starts
- would anyone happen to know the size of the license plate light bulbs? thx
- Front Caliper boot torn - I STFA and found the rebuild kit for the rears
- Information Display Module....2000 A4 2.8l Quattro with tiptronic
- Anyone use one of these to keep from getting a CEL with high flow cats or test pipes?
- I must thank this forum for all the knowledge i've gain throught the years.
- a whole bunch of ygm
- Day 5 Widebody: My fender finally looks like a fender.
- Anyone got their shipping plugs for their E-codes?
- Is the arrowed area where the tensioner for the accessory belt goes?
- One-touch up rear window mod FAQ thing...
- anyone have a front plate bracket?
- does anyone have a link on front door panel Removal ???
- Did something get a 600% increase in value this year?
- So what does it take for a car to be considered "totalled?"
- What are used stereo components worth these days?
- looking to buy a certified 2003 A6
- I have issues.
- Anyone want an eastwood 10% discount code? If so send me an email.
- Hey IwasAwesome...
- When buying a new key and clicker, where do i get the immobilizer chip programed?
- Bose (2000 A4 2.8 Quattro Avant) need help with this one guys
- DHL Rant part 2
- rear wheel bearing?????
- Looking for ignition
- Is the dual rear fog light mod the same for 98's?
- Looked around but nothing like mine...similar...but not exactly>
- Can someone upload a picture of a 1.8T engine with the timing belt cover removed?
- hey b5er's. I just picked up a mildly driven 2001.5TQM over the weekend
- helping a friend find wheels w/2000 A4, w/ Iibach springs and....
- Help me analyze my oil leak and it's relationship with the Breather Hose To Valve Cover 2.8 30v.
- Cheapest place to get B5 A4 H&R coilovers?? (no S4's or Ultra's)
- Paging Carson: Is the new Riverside showroom (RT3) open yet??
- I need to sell my car...
- Best and most inexpensive way to upgrade to HIDs?
- Lol Best Tail light for the B5 "i want them to pimp me ride"
- I'm super-impressed with DHL, and my turbo's travel route.
- Swapped clusters with a reman, now I get two codes:
- Can anyone tell me the part number? Fuel Level Sender for 01 a4 1.8t.
- Here's a good resource for those who get their own parts...
- Best sunroof track lube ,found the info again ...Nye Rheosil 500F...
- What does shokan carry?
- Vacuum Hose leak P1136 help.
- Can someone with an early(97-98) 1.8t check the sequence of colored cables on their MAF harness? TIA
- s4 rear bumper
- Anyone got an extra front license plate holder they want to sell me?
- Long time no see, AWer's!!! Anyone selling their 1.8TQ's in the Northeast?
- I just drove the S5. I like it.......alot.
- Update on my quest for quality, local race gas ------------->
- catalytic converter
- What does the 'carpet' under the knee bolster do?
- Shopping for some new wheels
- Did that Labree HFC group buy thing get deleted?
- Day 4 Widebody: My parade was rained on...
- What are my options for a different engine other than stock.
- I have a totally different perspective on my car....
- Starter Replacement
- Please compare: Miltek vs. Borla and APR vs. GIAC
- Help with suspention.
- anyone need a set of 16" sport (swing) wheels for your winter tires?
- vw sunglass holder
- Crazy ?: Anyone running stock w/chipped only? You know, before you went all-out...
- ICM Failure Prevention (in theroy)
- More power steering issues...
- Anyone willing to help me make a new sig out of this image?
- Fall Finish! Boston Area GTG 10/23 AMC Burlington
- !!!B5.5 Super Street Style OEMS RS4.2 Grille!
- Can it be done? 2.2 20vt AAN I5 in a B5 A4?
- adjusting e-brake cable
- Front Window Defrost/Defog
- OMGHI2U!!!! "OEM Audi RS4 Hood Grill"
- Wanna try to get that TMT Euro S4 Bumper. How much to ship from Germany for a large item like this?
- plan of attack for occasional rough idle
- To ceramic coat or not?
- WTB: Used Awe boost guage (B5)/ FWD/Manual or Tip Exhaust
- soo... atp wants 120 shipped price for an oil return line but don't even have all the parts =(
- Does anyone near NYC have some stock 15" wheels they want to unload?
- could someone give me a list of things they do for a normal tune-up
- soooo changing the shocks and
- So what is the preferred winter tire? I've lived in Florida since I was 4 so this is all new to me.
- Considering '00 A4 Avant 1.8T with 108K miles, what is fair price and what to look out for?
- Paging *andysprague* about oil return line
- Missing under Acceleration
- Installing the daylight running lights (LED) from the S6 on a A4/S4 B5
- Andy did you get that WG yet?
- CRC #05105 - for use as a sunroof grease?
- Anyone with a Hub Shark near Marlborough, MA 01752?
- Day 3 Widebody...The ball is rolling...
- changing shocks and springs any tech articals or writeups?
- Car will not start...please help..very confused
- Little CF install update
- Please clear up a rumor about S4 to A4 brake conversion....
- Coolant Temp gauge problem...
- Very strange hesitation since it started raining, yes I STF too...
- Is this just news to me - but the new A4 B8 is brining back the 1.8t
- Well, hopefully this isn't one or your own on here
- How much could I get for these parts?
- HA! Want to hear something hilarious?! READ THIS!
- PES people, FYI - response from GIAC about availability of encryption boards and chips
- Anyone looking for a project? Hows this sound?
- Exhaust options for a 00' 1.8T Frontrack Tip
- for APR stage 1 would you (the aw community) recommend changing out
- Anyone here know where I could get an Arnage for cheap?
- I found writeup, but how long should it take shop to replace fuel filter? They have never done one,
- 1998 A4 quatro 1.8t clutch bleeding woes!
- Oops, will these fit? old man winter commeth
- Where is my ECU?
- Where to buy Philips xenon ballasts
- autocross help
- What not to do with your Audi when frustrated with it.
- catalytic converters
- 20psi to much for this part?
- No plastic washer in my purems.com cv kit. WTF? How long can i drive on this, because its 9pm sunday
- ups!
- Low, loud roar at highway speeds
- Has anyone had to replace their camshaft actuator?
- AC blows hot/cold/hot/cold = weird
- Misfiring/Spark plugs Question
- control arm brands, which one to choose?
- Pulled fenders/widebody day 2:
- Headlights
- SEX
- I have another quick question. What size fuse is needed to run S4 fogs? 15amps i thought...
- I started reading this book recently
- 2003 A4 1.8T
- How can I keep lines for H20 Injection from freezing....besides increase alch %.
- Fvck...>
- Race fuel question.........
- Clutch recommendations for stage 3+?
- STUCK doing suspension install. I have a question for you snow birds on the forums
- I do NOT wish this to anyone
- Found this and thought u guys may be interested
- intercoolers + salt in winter...
- B8.......whats everyone think?
- Tracking parts shipping ground across the country FTL...
- Anyone know a good local RECARO retailer or source in SOCAL? Looking to get some Toplines..thx
- anyone in nortwestern jersey with a ch ecu?
- can i repair my headlight? all 3 brackets are broke off. i have two and 3 screws.
- Timing Belt screw up - Help Needed
- Car and driver called 2 nites ago... more later
- Is there anything bad about using a orbital polisher to apply wax - it is so much easier and faster
- getting a new headunit.... maybe
- My accessory belt is squiking like crazy. How do you tell which pulley it is?
- I'm in ur engine bay stealin' yur lights..
- fluid identification please... (2001 a4 1.8t)
- Hey what do you guys think about this one? I want it lol
- While changing brake pads today, noticed...
- car is ready to get cut up tomorrow...
- anyone parting out a 2.8 12v?
- So what do you think i should go with now...
- Cooling problems...
- Alignment update kinda of intresting for those who care
- Not much left holding my lower engine cover on .....need parts info
- Quick Question(Y or N): Do you have to have those special tools to remove head unit?
- Need help please..Just had my rear wheel bearing changed and now...
- yet another N75 problem
- 1 piece S4 xenon headlights would require the same modification as 1 piece ecodes correct?
- !HELP! Ran into a problem with the CV boot replacemnt, I think i screwed up the inner cv joint . . .
- Electronic Limiter
- Brecht BMW Tells Customer "Go Back To Volkswagon, You Don't Deserve To Own A BMW"
- Is anyone running a BT (bigger than K04) on a 97 1.8t??
- Time to play everyone's favorite game: What's it worth!?
- Need to do a oil pressure gauge set up - any links to what parts i need from 42 draft design
- can i use this rims on my 96 A4 quattro????
