- blacked out roof
- spark plug Q's
- with the A8 rotor upgrade and slotted rotors you will have some serious water splashing problems
- Service light reset in trip computer.. 2000 A4
- small fault code listing
- Is there something wrong with the search? I cant seem to find fault code 17763
- Seriously... where did the school bus full of held back students let out?
- TT Wheels on A4?
- Where do I get alignment (toe settings) specs?...
- Finally got new rear pads and rotors on....
- Safe to run K04 chipped for a few days w/o 5 bar fpr?
- Will a Delta stereo work in a 96 A4 that had a BOSE system?
- will the gt2871R upgrade fit on the pes t28?
- Flushing the car and wondering what weight and what type of fluids to put in everything....
- K04 on a B5 Tiptronic?
- 2.8 vs. mkIII
- ECS VW oxygen sensor for ATW engine?
- exhaust for a 2.8
- Does neuspeed.com send you a confirmation email when you place an order?
- I was thinking about injecting some grease into my squeeky rear control arm joint...
- AC Lines under oil pan crushed :(
- fresh oil, filter and new jerzee license plates
- 1st attempt at a sig
- Tie rod end advice needed
- Supersprint headers/exhaust for 30v 2.8?? Anygood?
- 01 1.8T Quattro vs 03 Maxima SE
- How long do tires stay good/useable when they have been off the car?
- how do you replace the bulb on the side panel turn signals on a 99.5?
- which chip is better?
- Transmission Filter Kit; Part Number 01V 398 009
- Fog light replacement - 2000 A4
- real quick guys (FROG!) what's the newer larger oil filter part# and oil capacity?
- Yay, going on my 3rd set of lower control arms!
- Intermediate Silencer.. get or not???
- Put my Bilsteins on about a thousdand miles ago.....
- ugh... compulsive parts purchasing
- Does the stock SMIC for a NDBW 1.8t use any sensors?
- Finally!
- FS...B5 A4 full Samco Sport Boost Kit in blue....
- Well guys, I Picked up my replacement A4 on sunday...
- Faulty Gas Gauge / Speedometer and RPM stop working / All lights show up split second.. HELP.
- Building a strong lasting engine at 103k miles
- Going the Blackhawk Farms?
- Just found this... customized badging...
- i need to anti-sqeal compound on the back of my brakes, do i need to bleed them? at any point?
- Any good Audi Technicians looking for a job in Boulder Colorado - Stammler Imports
- Anyone know what mount can be used to replace the one that comes with a DTS?
- Re-bed Hawk HPS pads? They are starting to sqeak.
- arm rest fix? (cross post) one more time
- Cool Beans... Intercooler piping should be here tonight.
- license plate mount won't come off
- What are you stage3+ guys running for spark?
- ot: bored? read some vwvortex stupidness.
- Can anyone assist with a part number for a heater core for 2001 A4 1.8T? TIA!
- has anyone bought the Neuspeed 1.8T Hi-Flo Turbo Air Intake Pipe?
- Hesitation at 4k rpm...
- ECodes?
- Anyone else find the phatnoise controls confusing?
- Day 2: Brakes still clicking. Desperation setting in.
- Response from ATP on 3" inlet pipe...
- trunk release on a 2001 A4
- Weight distribution
- Rear bumper options after an accident
- the car is going up on jackstands today....
- craziness, RFID in license plates!
- 1/2 way done with the T28 install...all old stuff (turbo, manifold, etc) is out...
- x post Is there a year when they only mfr'd leatherette? or did every b5 have an option for cloth s
- Keep your keys out of sight (Weird, semi-OT story)
- What to do???
- 37 different kinds of pissied off
- dealer price...
- A4 B5 Control Arms
- Problem Please Help:reinstalling ETKA 5.3 code 304 hardlock not present...
- What kind of foam to use, and where to get it?
- coolant not taking from reservoir, overheating please help
- anyone konked out their radio trying to remove it?
- side turn lamp....
- Does this sound ridiculously expensive?
- Question about high-temperature paint
- Those on STOCK CLUTCH, on k03/k04: Can you peel out in 1st, or chirp in 2nd?
- So a guy i know is getting a k04 put in soon and he has
- Classifieds are down
- If you have Neuspeed race springs please post pictures, thanks.
- trying to replace passanger xenon bulb (MY00)
- if i drop put a '99 head unit into my '97 delta non bose. is it pretty much plug and play?
- tail lights
- Got quoted for fender replacement...(EricBss7 look inside)
- H&R Cup Kit, anyone have it? Pictures please!
- Fixed the front end rattle..
- Everyone with Vogtland springs post a pic, getting mine installed in about 10 days..
- How fast has everyone gone? and state your car (just curious)
- what the fizzle(FVCK)?
- Five bar FPR Question
- Anyone have a spare cup-holder assembly?
- did another hour of pinstripe removal today
- What the hell is this???
- would this one work on , my baby? K04-15 Audi / VW 1.8T Upgrade Turbo - Borg-Warner - NIB
- Does anyone know if the gills on the kerscher bumper are fake or if they are actual openings?
- I'm a dumb ass...need help. 1st oil change and can't find the damned drain plug...
- Need a Center Cap for 2001 17inch 9 spoke (silver)
- Got my VAG-COM today and it works...but I don't know why I'm telling you that.
- Did a compression test today...
- Anyone else shudder when they review their mod list?
- clear corner mod question...
- Anyone know the part number for Aux / AC fan? 2001A41.8t Please Help!!!!
- I just got my abs computer back from modulemaster.com and everthing works great!
- A4 Air Conditioner Doesn't Work - High Side = Low Side = 125PSI
- For the North NJ crowds
- Does anyone have a DIY heat shield template they can send me.
- Question for "ollonglans - A4 tdi" or anyone that can answer
- A/C Compressor Type
- Anyone with a used P6000 SV? 205/55-16, Mine blew...Pirelli blows.
- Need New Clutch...
- brake fluid reservoir
- Any Audi lovers in the Lehigh Valley looking to break some legs? hit and run on Saturday night
- buying a clutch and LWF. i just dont know which to get. oppinions?
- Just curious, how do you think a GT28 would be on a TDI?
- Coolant leak or evap?
- question about bleeding brakes
- Just picked up Denso K20R-U11 spark plugs...
- Sloppy Shifting
- DIY short shifter or any shifter installation helping tool
- thats how my autolite $1 copper plugs type 3923 were gapped after 4 k miles
- Now my next question about the turbocharger
- Phat noise system questions....
- Top speed of a 1.8T without limiter? (im guessing restricted by rev limiter)
- this should be a fun one, what was your first engine mod?(list 1.8 or 2.8)
- 1.8T With Leather?
- im having tinters remorse, i should of gotten darker :( (sig for refference)
- I'm about to pull the trigger on another set of Yoko AVS ES100s. Any reason to get something else?
- not an A4, but you GOTTA SEE THIS SH!T !!!!!!!!
- Tensioner Settlement question
- I just ordered Bosch Red Tops. Will I need spacers for them?
- OT: Test drive: 2005 Legacy GT Wagon turbo, long
- 215 or 225 tires on stock 16" rims?
- Brakes still clicking after inspection. Help!
- Thinking of upgrading stock bumper to rieger rs4... Opinions needed
- where is the best place to get a ballast for xenon light?
- Had steady 21 boost....now only 12 with slight studdering???
- A4 body kit questions for 99.5.
- Gonna spraypaint the hubs of my new brake rotors. Anything I need to know?
- NEED BRAKES! Where and what to buy without breaking the bank
- A4 1.8T quattro rear end noise
- My Starter may be going.....
- Anyone running Greddy G2 exhaust on a 30V 2.8?
- I need to know the aux fan part number for 2001 A41.8t..Please help
- cooling problem- need help please
- What's the concensus on a broken FPR hose- lean or rich?
- BPV or BOV?
- Problem with rear brakes
- New Shoes Black A4 w/ 18" Anthracite Wasps
- So, all you B5 A4 guys, I've got some parts, cheap for you.....
- Repost: for the weekday crowd... Carrera GT, Audi, Ferrari etc...
- Some pics from my A8 brake upgrade last week...
- Oil Leak
- i think i have a slipping cluch
- sequential trany
- Is Neuspeed's Engine torque damper bushing the same as a snub mount?
- do I have to Drain transmission Oil _>Rear trasmission/final drive
- A4 V6 2.8 Auto ->How many transmission oil (qtr) do I need?
- Have a 98 A4 Quattro 1.8T I was woundering what is the best turbo upgrade I can get for my baby here
- Well came out of the movies tonight...
- 8D0997558HX or 8D0907558B, Will these ecu numbers work on my 1998.5 A4 1.8T?..
- can you help with the rims
- 111111
- does anyone know where the a/c lowside is located?
- JohnnyRacer Intercooler finally mounted the way I want it.
- K04 GIAC chip and FPR from Feb. '04...OK to buy???
- pics with the new camera
- xenon light out
- So.. selling one of the bikes.
- Front mount Intercooler question
- Time it takes to install Coilovers and all new control...
- So what companies will write custom software for bigger Turbo setups?
- Need aeb wiring diagram for engine
- are u guys gonna make fun of me if i make my car like dis?
- Need Info on K04
- People, be patient, BWW, but sooo definitely worth checking out... You will thank me... The GT
- A few clean car pics with my new camera (BWW)
- just had one of those chats with my father while putting out the garbage
- Well i think i've finally tired of my 'money pit'...
- Santorin rocks when clean
- My ModuleMaster Experience
- Boost leak tester question
- Where can I get RS4 rims. 18in w/tire package. Any better deals somewhere?
- hmmm that mothers aluminum polish does an alright job on the avant roof rails.
- Aftermark Accessories for the A4
- 99 A4 1.8T Radio/CANBUS Question
- Darn leaking imput shaft seal.....
- Cat convertor assy
- I'm addicted!
- Part number for body plugs...
- Valve cover gasket
- need new tranny
- Symptoms of a bad Diverter valve? Will it send you into limp mode?
- that would hurt
- When quickly reving up from idle, engine bay makes a loud metal tapping sound?
- compression ratio 2.8l 30v
- reposted for the day crowd, my new tints...
- woodward dream cruise parking / bbq
- pin stripes on passenger side are gone.
- Does anyone know "Joe (zyxt)"?
- where can i buy new control arm bushings? 99 A4
- parts for sale
- help replacing spark plug wires (aka ignition wires)
- look for a local audi/vw shop
- I'm noticing a sort of haze on my headlights caused by what I imagine to be...
- HELP!!! A!Avantgarde/Erebuni bumper help PLEASE!!!!!!!
- Radio code help '99 avant...VAG help??? charlotte, nc
- 1999.5 1.8t manual needs a new clutch.. any idea how much it will cost?
- Splash Shield Bolt Specifications
- anyone have one of these lying around they want to sell
- Oil Cooler on...
- weird alarm problem
- TurboSmart Kompact hybrid set-up...
- is it possible and worth it? switching black trim around windows with chrome?
- some FL member went to atp to get a turbo kit...
- cel again
- my baby, 35% tints. thanks to those who recommended the tint shop in edison
- RAZR V 3 TPIWWP
- with all these different and custom tuned turbos out there, who is running what now?
- Can anyone here get me a replacement fender, if so
- Changing Brake Fluid Involves Clutch Bleeding?
- My household buys entirely too many tires.
- K04 Chips...dahlback?
- a week ago...
- 1998 2.8 tiptronic diag. help please
- I FINALLY fixed my Jeep!
- Repost for the B5 forum: Dont know why my K04 is overboosting
- Water in the battery compartment
- Had a little fun last night... cars coming along.
- dahlback racings show truck... this thing is a beast
- New battery
- as posted earlier. plier number 3 or 5... whats the name of them?
- Looking to do my control arms,and had the dealer do the lowers for the recall. . .
- Bad tie rod?
- springs or coils?
- USED coils?
- ATP GTRS pics inside
- Anyone have a pic of an A4 with an S4 grille and stock lower grilles?
- K04 chip question...
- Hesitation at low RPM's and now no throttle response...any thoughts?
- Last Call: Tecate Beer Brewery Run...
- I need a flange to connect to the exit side of the stock cat, does ATP carry them?
- Catalytic Convertor noise
- can anyone give me a part number for the most current coilpack?
- Aftermarket Headunit Choice
- Could someone do me a favor?
- 317cc injector problem I posted last night - any daytime guys got any input?
