- More spring questions. Why does no one sell OEM rear springs?
- Nasty Creaking/Groaning noise when turning the steering wheel
- Hit or Skip - STaSIS Street Sports + H-Sports with tax return check.
- more boost issues....help?
- Wheel size with Stock suspension
- removal of flasher relay assembly 99 A4 avant
- Uch.
- I think I've got my intercooler plumbing figured out.
- When replacing suspension should new shock bushings be installed? the car has 66k on it
- crazy mofo dog leapt up and landed paws under my passenger window, and slid about 3 inches with
- vag-com tech tip...connectivity problems? bad ABS computer? unplug it.
- Alright, I bit the bullet and picked up the Garmin GPS 18 for $115. I'll post picture when I get it.
- i think my car adapted, or i got a bad batch of gas...i just logged my PB CAPS of 6.13
- Just got word from shop:: : For once i couldnt find a problem, maybe this is why
- Now my turn to ask a question about brakes????
- Noob Suspension Question
- brake pad light came on "(0)" but pads look totally fine
- Doing CV Boot, do you turn the pinch bolt to remove it or hammer it out?
- Airbag delete mod for the seats - which 2 holes to i stick the resistor in?
- What should I ask...
- Obvious statement of the day: Stock SMIC sucks bawls....
- Cheap rear struts/springs.
- Today's creation: Ported & powdercoated OEM exhaust manifold:
- tiptronic tranny problem
- Drivers side door latch
- Where do I get a solid Cal rebuild kit? Stock fronts.
- Weighing new car options
- Slightly raised coolant temperature... what is the likely culprit and should I be concerned?
- ECU or Speed Sensor?
- Looking at purchasing a Garmin GPS 18 v8 for my laptop
- Mark 3 VW Beater car FTW!
- Well I'm off for 3 weeks, see you all when i get back
- Oil Pressure Light - help! what to have checked?
- Did the search, and it looks like noone had this problem before.
- Very OT...but incase some of you want to see. This summer, black is the new black.
- Coolant leak+whole system flush. How much will that cost me?
- been working away.. signed it just to say .. DAMN HOLY FVCK mikehood!!!
- Want to rebuilt front Cals. Stoptech sells kits. I just have stock Cals though. Which kit? Plus..
- What is your thought? Most productive way to change starter Audi A4 2.8
- Dumb Q - What is this? Engine or suspension mount?
- Yah or Nah - adding a sun visor strip on the top of my windshield. Black?
- Would you trade for a Cayenne S?
- Any one in Las Vegas who wants to change my starter, i will pay.
- Just finished body work on my bumper!
- Turbo kit install instructions.
- some car pics from today
- What is on my new wheels?
- Who uses the Boost Machine by itself? Or which N75 are your running it with? My brother...
- Having some Issues During a Long Trip
- In search of a rear deck 6 1/2 inch Bose speaker
- anyone else keep breaking CV boots?
- Is my ICM bad?
- I'm looking for a part number for the clutch interlock for my 2001.5 ...
- Hitch question
- Where is the "plug" end of the outside air temp sensor
- So I went to my first drag event last night
- Having some trouble removing the seats - is there a write up - that has pictures
- how the HELL do you remove the rear wheel bearings and/or ABS sensor?
- Searching now!! But, does anyone know symptoms of incorrect ATF , tranny replaced,
- Engine Grounds....Where are they?
- Does anyone know the part number for the clutch switch? I will need to get one soon... (I think)
- Full Power, Turning over but won't start... Please Help!
- Where can I get just inner tie rods (no TREs) that are high quality?
- Was going to try and DIY some octane booster but....
- Well the video of my dyno run is now up.
- Does anyone know the link or the write up for an airbag delete mod for aftermarket seats
- Radio removal tools are stuck...
- Any idea what a GIAC chipped CH box is going for these days?
- Unbelievable!! Clutch bleeding problem solved.
- P/N Request: Passenger's Side OE Brake Caliper
- black smoke
- Trouble bleeding 1.8T clutch lines
- Bike hitch questions
- OT: Jetta MKII (1991)... bolt pattern? 5x112?
- Desperately need a stock dbc ECU, No one has one by me (nynjct forum)
- is there a write up on how to drop the oil pan? I want to clean out the oil pickup screen/tube
- Whats your creative tool for tightening the one time use clamps?
- Is there a pattern for the failure of the clutch switch? Or does it go without warning?
- Squeaky steering when turning right. (How do I remove knee bolster?)
- Hahahahahahaa.. WHO on EARTH would buy a car from this guy?!
- Intake on my AEB?
- I just noticed on my old spark plugs that there's no oil on cylinder 4's. PCV servicing did it
- bored late night (pic)
- I think I blew my CV joint....
- Need some advice for clutch re-install...
- External Temp Sensor
- Instrument Cluster Failure - A Call To Arms!!! Please Read!!!
- lookin for ideas on my boost leak....tia
- 556awhp (Dyno graph now added)
- How much do stock sport leather seat sell for not three fifty if they are in 100% perfect condtion
- Anyone know if a front door bose speaker from '05 will fit my '99.5?
- The worst part of owning this car>
- Beefed up Swaybars or new shocks?
- What other engines will accept, witout mods, an AWM head?
- OT - but hysterical.
- Turn signal issue
- ok, now my car is driving like a raped ape. (which is good)
- i need to source the following really quick and really cheap
- keep a4 and supercharge or sell and buy b5 s4...more...
- Air Dam
- how much for a new OEM rear bumper and shocks that it mounts on??
- Black corner light FELL OFF! Where to get new set?
- Tryn to change fuel filter but both bolts holding it to the frame are stripped any tips?
- CF Trim Update: X Post
- Just had an alignment: Tech put the fear of early tire death into me for lowering. Advise please??
- who wants audi adjustable control arms
- Anyone have a stock CH ECU from 2001 A4 they want to get rid of?
- anyobody know where i can get 19.x10 deep dish rims and who makes them with like a 3-4 inch lip
- I was cleaning up my winter wheels and found a slight bubble on one tire.
- External Temp Sensor....Cord haning from bottom of bumper... HELP!
- ETKA guys: please post the tranny bolting up to the bell housing showing the bolts.
- Part #... glove box shock... is it the same on all model years?
- heads up to anyone with an Avant, and wants a cheap springs/shocks
- hmm..
- If Neuspeed exhaust = Borla, will the newer Borla aft muffler fit right on my older Neuspeed?
- Torn CV boot/ worn TRE's/ "bad" A/C compressor...
- Wheel bearing.
- A friend of mine is looking for a 1.8T manual.
- Anyone try the Pwrhaus FMIC?
- Worked on the black car over the past few days... (BWW huge pics!)
- Any place still have Grooved Bilsteins?
- *formatting really old laptop with win98 for vag-com* god this sucks.
- tick tick tick... tick tick tick tick tick... from left rear wheel randomly while driving.
- Ebay car of the week - Has HKS blowoff and it is real loud hiss that can be heard for almost 1/4 m
- Bent fins on my k04 = negative deviation & limp mode
- Those who upgraded to HID - did you have to change your fuse from 25 to 20a
- sunroof works but wont retract
- I want to update/renew oil lines. Where do I get em for K04? Can I do better then OEM?
- Borla million mile warranty is suboptimal...
- Props to Andy at Southbend. Got the clutch out, sent it to him, I am not the purchaser of the
- General Exclaim UHP tires-
- southbend screws me again
- Oil pump update X-post.
- Pics of cars with bilstein/h&r sport setup
- APR Now Provides Financing!!!
- Part # please for mirror switch.TIA
- :: ECS Tuning :: OEM Replacement Breather Hoses and Check Valves
- having trouble finding the correct ac condenser... help plz
- Another big thanks to AW (Long)
- Discounted clutches! Spring clearance... Save $154.95!
- Need Advice: Headlights shake (euros) because I don't have third bolt. What to do? Zip Ties?
- 01e 5spd CONVERSION 01a 6SPD
- Who's got ASA AR1 or AR2? Post pics, Thanks
- CAPS LOCK
- FOG LAMPS
- CHECK ENGINE LIGHT
- what size trix wrench do i use for my breaks before i strip something????
- pvc part # help needed
- #$&*$$#$#!!!#$%^#@!!! It Figures.
- Need to replace drive axle on the Passat. Is GSP brand any good?
- give me your best device/way of pressure testing the intake system..
- Just sold my car...it's been fun...
- Any tips on adjusting coilovers?
- Koni coilover question?
- Just took the first "spirited" run of the season with the A4..
- A+ to mike@purems (again)
- full gt28rs + APR exhaust, compatible?
- I'm Running the First that I know of audi/volkswagen Island cruz;)
- Audi adds 1.9 TDIe to European A4 lineup (Sadly not in the US.... yet)
- What is the best coilover system for an 01 A4 2.8 quattro? Thank You
- What is the sensor in this pic that the yellow wires go to?
- Does everyone switch to the through bolt design when you R & R the frt sway links?
- Simple Question but something i would like to know.
- K04 in and running sad news is still smoking....
- WOOT to APR Stage 3, suspension set down and firm, fmic fits and new sneakers on her!! YAY!
- anyone ever have a rebuilt turbo go?
- Is it necessary to clean the IAT sensor. Intake Air Temp. Y or N and How?
- I polished my headlights today.
- Feeler: Anyone looking to sell off your OEM sport suspension for my '00 Avant Quattro 1.8T Manual?
- So who's had a BT lying around for over 3 months and also didn't install it? I am going....
- I've been really bored all day and started to ponder a homebrew kit.
- I have 3 Questions...legitemate ones. TB, ARX and HEAT.
- Speed Sensor to connect Navigation system
- Help with drivetrain noise
- Anyone tried the 034 clutch kit?
- How do you remove the rearview mirror from the windshield?
- Can a bad feul pump relay cause the car to randomly lose power while driving and to not start?
- Europrice Leftovers Sale, it's on the shelf, it's dusty, it's priced to go...
- FMIC installed, losing about 2-3 lbs up at almost 10,000 ft. above sea level... more...
- YAY for real RS4 engine mounts & siemens 630's
- My parts are dwindling
- So I log blocks 115 & 32...Experts?
- Props to Andy @ South Bend Clutch.
- abs at low speeds?
- Dungblog #? Avant reconstruction: Stage three = WEEEEeeeEEe!!! ~ It's in, major issue though-->
- What's the latest consensus on the best value turbo upgrade for our B5 1.8TQ?
- oil light likes to come on when I make a hard left turn
- ETKA help fellas...
- So Ive had an ongoing CCT problem that I never fixed since I was under the impression that it
- Will 245/45/17 tires fit?
- Is the cars VIN encoded into the ECU? I doubt it but wanted to ask.
- looking for some opinion on my pvc system, thinking about installing a catch can
- Cleaned epl ecu throughly w/ alcohol and let sit overnight and car still doesnt start
- Wow, NJ has some really odd registration fees. My 99 A4 will cost $46.50 to register....
- Dropped the oil pan on the caulkmiester...again.
- Q's about Police Speed Guns
- 99.5 A4 1.8T Quattro problem...??
- overheating update- Fixed!!
- What do you guys think
- So I saw a tastefully modded 06-07 Volvo S40 T5 today in South Jersey....
- Any idea where I can purchase a new connector for the lower coolant sensor?
- Window defect
- How many of you admire the C6 A6 as a next car / upgrade?
- convert 98 gauge cluster to 2000 can it be done
- 2000 A4 Quattro 2.8 hard to start when engine warm; code P1296
- 01 manual 1.8t a4 with 57K miles. I can feel a like clunk when shifting into second and twice now...
- Does anyone have an extra turbo support bracket or know where i can get one thanks
- quattro mk1
- slow in here tonight then?.....
- Valeo e-codes
- Has anyone here (besides me) had to replace both motor mounts?
- I need a rear wing! Avalon has a Hella, and there's a similar unit from Spoiler Depot
- Vogtland or H&R springs...
- Strange Leak
- audi diagnostic software
- Is there some sort of emissions readiness guide?
- Tingle, tingle, sparkle... (56K roll over and die!)
- What triggers the electric aux fan in the engine bay to come on?
- Steering Rack Issue
- The luckiest 96'
- I'm replacing fuel filter, and I only took off 3 washers. 2 on the inlet...
- Parts needed for putting 1.8 tranny in 2.8 car?
- Mica's guide to writing a good 'b5 a4 for sale' ad.
- Help? Need a part number ABS sensor, front passenger side, 97' A4 fwd.
- I gotta admit the faq on audidiy.com has gotten pretty good...
- Carmax: Borla Bad!
- Question: : If a Fuse isnt getting power....and isnt blown (#34 Engine timing)
- Sideline Sports photos from our spring track day and GT30R coming
- Quickie: can the exhaust manifold be replaced w/o removing turbo?
- Another happy customer from raxles ...
- - Paging Ryne O. -
- A.W.E. Tuning "Partner Spotlight" - BHR, Inc.
- Whoa this is a piece of... *REPOSTED*
- Huge Props to Koni North America
- Car woes x-post.
- stay tuned for some funny vag-com logs tonight. i noticed a "tear" in my APR TIP last week.
- DBW - ndbw ? mike hood, tightt
- Need a little help please...I got my ATP high flow manifold and...
- RPM'S Fishing
- Remember, you can only choose two:
- Identify leaks and how to fix...
- Washed Car!
- Removing center panels
- *Wipes sweat off forehead* Golly, changing the 1.8t air filter sure is fun! :P
- APR 91 chip???
- Random pic time....
- PiCtUrEs FoR yOuR eNjOyMeNt!!!
- Black S4 auto at the auction tomorrow....... Gonna go cheap i think.....
- will a bad rear wheel bearing cause the wheel to wobble? bolts are tight, but when driving it
- tech replaced heater core, now A/C isn't working. related?
