- needs help with windows
- Audi A4 with 190,000 miles
- Put the Neuspeed Extreme inlet hose on today
- Replaced the tranny mounts today, not too bad, more problems though
- The driver's side door latch/handle (the one with the door lock button) on my car made a weird
- *sigh* Some day, this will be mine...
- C'mon Brown!!
- hmmm. i know 225/40/18 is the norm for 18x8s... what about 18x8.5? 235s?
- Creaking with my stoptechs?!?
- This is my kind of grocery list.
- OT: some neat Blue Angels Pictures from their show today
- URGENT HELP: Timing Belt Mark lost
- anyone have stock sport swaybar bushings they dont need?
- HELP! serpentine belt partially tore off today... probally about 1/5 of belt totally off..
- anybody here use redline "water wetter" ? and if so..results?
- Looking to buy 18" rims
- topspin lip spoiler??
- Question regarding the brake fluid lines under drivers undercarriage....
- looking for advice on upgrading...
- SOMETHING WEIRD!
- SWEET! New sport seats are in. I LOVE love <3 LuB LOVE them. ;-) Such an improvement.
- NEES HELP
- Quick poll -- new wheels (BBS CH, 17"): 7.5 width or 8.5 width?
- BAM
- Engine Noise
- BLKPERL: Is your car at APR yet? :D
- Iam not really that great in the audio department...so i need some help.
- Can I use H&R lowering springs while keeping stock shocks?
- I hate people who don't know how to drive...
- anyone have a part # for a new engine....mines blown
- First impression: ECS RA4 Stage 2 clutch w/LWFW
- Thanks AudiWorld!
- Paging: Inigo Montoya: Trip Computer Harness Question. Kinda Long...
- Anyone know the part# for the gasket that sits between the axle and the drive flange in rear diff?
- Anyone have a AC compressor for a 2.8 laying around before I goto ebay?
- How do I replace this?
- updating my 2 piece headlights to 1 piece, having some ?'s about the harnesses
- x-post from AWOT-- don't mess with the diesel trucks :P
- had a check engine light for three weeks and then all of a sudden it's gone.
- Using bolt/nut combo instead of shipping plug xenon housings.....
- Beginning of rant...... Uggghh. 65 in a 50.
- Anyone ever split a silicone coupler before? I had a 1" crack right in the middle of mine.
- STaSIS B5 Track Sport Suspension on Sale until the end of May!
- Paging Phil (Qfrog
- Any of you B5 guys paint their wheels black like this?
- Bird=1 / Audi=0
- what are the chances that a serpentine belt from a passat 2.8 will fit a '99A4 2.8?
- Update: still having what seems like fuel delivery problems after fueling up.. thoughts?
- Going to finish up installation of speed bleeders
- Anyone use green coolant in their A4?
- Help with lock carrier service position...audi tool #3369 thread type
- Fuel door cover
- Does anybody know what the interior color code GU (gray) translates to in english?
- Having a 98.5 AEB 1.8t with Forged internals, which turbo would you go with 28rs or 2871
- Help Please! '99 2.8 30v q
- What version of VAG-COM do I need?
- Well, the A4 will get some time off to relax...
- upgrading to ecodes hid w/ oem hid's for 97 a4
- Yesterday, I put all the bolts that I removed to remove my trans in the parts washer.
- How would I attach a ground wire to my ballast?
- sunroof
- If you had a set of 2x225 and 2x235 tires, what size would go Front, what in the back and why?
- favorite all season tire for under $100?
- 2nd timing belt in 18 months
- so how bad is it? wheel scuffs inside...
- Who's running a stand alone engine management system?
- New tire choices available at Achtuning
- Thinking of going with Red Line MTL (70W80) rather than the MT (75W90) to improve cold weather
- reasonable?
- Recent mods pictures
- Tonight is detailing eve..
- *blank stare* (x-post from audizine)
- Snubber Bracket w/Poly Mount, A4 (found this over at vwvortex)
- You can replace water pump without removing timing belt
- Does the tire rack include a set of hubcentric spacers with the purchase of 4 new wheels?
- Trying to diagnose Cruise Control not working....
- some pics from the SoCalEuro gtg
- How many '01 and '01.5 owners have Seafoamed their car? Intake?Oil?Fuel?
- Seen this again and again over the several years I've been here. I still have brake pad questions.
- Wow, just drove home my friend's '01 GTI...
- Paging Qfrog and other 99.5 Owners with a Bentley (Need Part # Please!)
- Did anybody buy EBC greenstuff (DP21114) from thepartsbin.com?
- Problem HID!
- changing whole drivers side mirror
- Are my calipers locked up?
- Adjusting Rear Koni Shocks....
- Progress pictures of my brother's 3B 20VT engine build
- Seafoam to the rescue! What ratio for oil?? Whole can or the 1.5 oz per quart as it says on can....
- Place your bets...Who will get the 300 000th thread post?
- Broken Volt Meter.....Can you only replace it, or do you need a whole new display?
- Spark plug replacement recomendations?
- I have read a few things regarding the bosch 440cc injectors while searching the archives...
- First repair I did to the avant...
- change of gear lube
- Kris Hansen, you might find this 3287a ball joint tool listing flattering ;-)
- Anyone have a spare CH box?
- Anyone have their leatherette driver's seat tear?
- Would an ECU from a '00 1.8t with a j31 file work on my 2001 1.8t?
- WOOT!! Big Brown truck just dropped off my new sport seats! ;)
- Has anyone figured out how to backup the eBahn content activation?
- need suspension suggestions
- Sunroof Clatter when open
- Sunroof Drain Tube Write-up
- Woot dubnation coverage of the event is up
- Will a forge 007 for a S4 fit on the A4? Are they the same product?
- Rear bumper removal: How?
- Putting APR Exhaust on car.. new OEM gasket enough for cat/DP connection? n00b -->
- driver side lower door trim is jacked!!
- AWM engine, Can i just replace thermostat
- though a month late, figured I'd share some VIR photos with you guys... BWW and enjoy
- Silver A4 mangled on Rt 80 west in NJ. Hope you're ok pal...
- 2000 s4 a4 compatable gauge cluster on ebay
- AutoRX treatment - interesting observation...
- was browsing through Startup Racing's website and noticed the Addco 19mm rear sway bar...
- One of the holes where my turbo bolts to exhaust manifold on the turbo are stripped.
- anyone have the strongest spring that comes with a new diverter valve they're not using?
- Suggestions on tires?
- anyone have a set of shipping plugs to get rid of?
- 3" testpipe downpipe deal on ebay
- Thank's Troto
- More of car
- more pic's of Car
- Hi I'm New here thought I would share my car's with you
- running a 332 front BBK, what's a good rear upgrade to balance the bias?
- Oil light
- is it so crazy to dream...
- RS4 Trans Mounts
- RACE RESULTS INSIDE - Please do not post in subject line for those who want to watch the race
- 400chp still the consensus for most power stock internals can handle?
- Starting problems...
- the mod bug has bitten.. need some advice
- follow up to previous post......double digit fuel trims
- Would this make me happy?
- GIAC K04 Software is in!
- any test pipe people try this yet?
- Viscous Fan/Clutch removal
- Has anybody done a homemade version of this?
- Rough idle troubleshooting...
- In teh mail today: One perfect, never installed E-Code ( least it looks brand new...)
- X-post.Any good places to buy wheel locks? Price?Links? Any brand is fine? Anyone selling their? TIA
- Coolant Flush? How does Thermostat work
- front bose speakers
- Need part no. for 2000-01 A4 and 1.8T rear deck emblem
- Write-up on Sun-roof Drains/Guides
- Can someone tell me what this is? Is is supposed to have a hole?
- Ne1 else see this whip someone put on ebay?? Looks pretty tight.
- Mass airflow sensor replacement
- MIL VAG readout "High Fan Relay"
- Why is the local aftermarket parts place listing two front wheel bearings for a 98.5?
- Sound like MAF to you? (long)
- Couple quick pictures...can't wait to get the 18" RS4 reps on. :-)
- electric fan question
- Has anyone here done the linkage mod?
- Anyone here running an ATP VES system? How did you have the plumbing done? impressions?
- S4 Xenon Housings on an A4
- whats a good set of coilovers guys?
- Anyone know where I can still find a new/used OEM rear sunshade?
- Possible to replace Water Pump without Timing Belt?
- How much would you pay for a used stock flywheel w/ 100k miles...
- Apparently they are droping 2.7T's into elises these days
- UNPimpZeAuto..... package shipped this morning. LOL, the box is ahh.... interesting.
- Some photos from this weekends big meet in Ventura
- PhatNoise out of stock at 1stvwparts. Any other sources?
- Can the radiator and/or water pump in a 1.8t be replaced without removing the bumper?
- SERIOUS HELP NEEDED!!!
- So I was fixing my FMIC this weekend and accidentally knocked off
- Child Restrain Options in B5?
- ABS Hydrolic Control Unit Leaking, 2000 A4 1.8T
- Vortex is not that bad guys:)
- Paging qfrog: can you please call me on my cell when you have a sec?
- E46 M3 Lip Spoiler - size?
- I put my bike up on the roof rack and forgot to secure the back tire...
- Last part number request, I promise...Crankcase breather hose. **EDIT**..
- does anyone sell a 3" downpipe for 1.8Ts?
- Convex driver side mirror
- Im having some really bad throttle hesitation with the 2.8Q
- Throttle issues
- 98.5 2.8 30V 105k mi exhaust noise when cold
- Stoptech brakes and wheel clearance
- 30 dollar lip spoiler...
- Strange small yellow box on rear deck
- Call me dumb, did apr make a tip chip and if so when?
- Hey guys any of you had experience with this site/company ?
- Went to boston today, record time for me, 1.5 hours.--->
- need door mirror
- Can I use my Vag-Com on other car brands? My dad just called to tell me his truck's CEL is on
- random picture
- Question about wiring in headlight connector...
- Amp/Sub gurus: Riddle me this; Why does this sub sound like crap?
- Headlight relays
- Installation of B5 S4 Chrome Mirror Housings
- Anyone here know about the installation of the wet brake kit?
- ECode - Is there a way to fix broken Alignment Knob ??
- feeler post: Any laser red a4s looking to upgrade to an s4 bumper?
- After driving around w/ the DTS for a couple days....2 nays
- Great idea for DIY repairs... Ramp Pit!
- Question about the banjo bolt on the turbo
- short shifter
- Bail out of 2001 A4 or mod?
- Water Pump
- Who knows bar (pressure)
- i nominate myself for the dumbass move award for the week...
- Quick review of the Vogtland Coilovers...
- HUCO ICU just listed in the classifieds.
- My oil leaking K04 - pulled it out...pics!
- need some help with possible secondary air injection problem
- !!!HELP!!! - Location of Starter relay
- Need help with rear prop shaft / transmission seal. A few questions:
- CV Boot problem!!
- guess that sound post. high pitch metalic noise comming from the rear of the car.
- Paging "a4nik8r" (sp?) YGM $$.
- INspection did not pass...
- "soft" alloy 17" 9 spoke wheel replacement 2001.5 a4 avant
- Chip for 30V worth it? anyone have one?
- Start-up of my new engine....
- Ray, Shawn, I'll be leaving CT bout 9.-->
- Flood victim needs elec help!
- chipped 18P ecu on ebay
- The car is paid off finally... Now I just need to get back and perform all my maintenance
- Trip computer weirdness
- STaSIS Motorsport has strongest team qualifying at Mid Ohio in 5 years of competing.
- Exterior Door Trim Falling Off
- cross post from the B5 S4 boards...looking for some input
- 2006 A4 2.0T Quattro 6-Speed or 2006 Legacy GT 5-Speed?
- HEH.... me chasing down an RX8.
- Big Master Cylinder upgrade
- good place to refinish my rims around boston?
- Unpimp Ze Auto: you get your package from me yesterday?
- Best place to sell modded A4?
- Did a compression test..is this good?
- CD Changer 98 A4
- my rs4 rims are peeling and bubbling, anything I can do?
- Short - harness from icu to coil
- I hate DCH Audi so much. Please, do me a favor and never give them a dime.
- HELP! *Stock Turbo Pressure Specs*
- will 235/40-18 provide curb protection on 8.5 rims? or 255/35-18
- Just pulled the following codes. Any and all suggestions needed:
- Just got in the spring kit for my diverter.. time to pop in the blue one and see how well it works
- look what fedex dropped off today.
- so my brakes are squeeking really bad when i am driving slowly/at the end of a stop.
- I just noticed my driver-side sideview mirror housing is cracked. Thinking aluminum S4 ones...
- ATTN: RayKhan-illbill---->
- Part number request center cap 16" swings
- You thought you guys have it bad with wheel bearings?
- oil temp gauge dead??
- Shep 18T/New to the board
- Repost for the Saturday crowd...Hi guys, really need your help here. I'm having overheating issues..
- Knocking noise when turning
- Intermittent car starting problems; I'll get a buzz sound from the ignition switch area
- 97 A4 Quattro stabilizer bar mount problem
