- Pic's of Yellow A4 with Euro's?
- i have an aftermarket (kenwood) head unit... is there any way i can run an ipod through it? i dont..
- Hit & Run This Weekend, Need Passenger Taillight. (99.5+)...
- Rear brakes squeeking.....
- bailout because of leg room problem?
- who sells the door sills with the rings logo?
- Why is manual rear sunshade incompatible with SIDEGUARD airbags?
- I STFA and still cant find a straight answer... what line should i tap into for boost gauge install?
- It's always odd to hear about audis on other forums.
- k04 sans everything else
- how much could I realistically get for my car?
- Hey Kris, I added the crest for you.
- Porterfield R4-S Pad's
- Couple hundred local miles on my new brake set up....... nice, more....
- T-28, APR S3 guys, if we could make it happen how many of you
- installed gauge rings
- Blue A4 with black wheels in Lexington, MA...
- I was at a VW & Audi meet this weekend
- HELP!!!... Cracks.. lots of em over my engine
- HELP......loud noise under the front right side of the car...
- Oil Change
- 152 vs 153 toothed timing belt on 1.8t AEB motor
- Some nightshots I did tonight *56k beware*
- New brakes... 8^D
- So what is the DEAL with ATP GT28RS Turbo KIT?
- what exactly do power pulleys do?
- lucky numbers for fathersday! happy fathersday to y'all!
- gotta love open highways....and more random pics
- PAGING Big Nipper...or anyone else who can answer my question....
- Club Audi Victoria now on www.audi.com.au! Check it out! And Join if you are not yet a member!
- damn reflections! should have had my tripod
- About to attempt Oil Pan Replacement, a few questions about engine lifting
- Flik Justice Question
- Where can I buy adapter for speakers and HU?
- does any one have a picture from under the car of the flex joint and the down pipe???
- tightening your belts
- What's goin on fellow A4'rs?
- Anyone have a website for GIAC?
- Need help with rear caliper rebuild.
- Fresh car pics...
- Stage 3 BT: are you satisfied with your cars performance?
- Clutch Replacement
- Strange engine behavior after long drive from high elevation to lower elevation (more)
- repost for today crew
- Never Used Milltek Audi A4 2.8L 96-00 Exhaust System
- Bicycle rack questions.
- need a sig badly....
- spuddering, boost gauge going crazy...
- Design tech bbq + hooters show..
- How much of a drop would i need if i have stock sport suspension?
- I am teh race car driver! Big pic...
- Question about an A4?
- Considering getting an A4, questions inside!
- wiring a boost guage to light up with headlights
- What are people selling/buying X-Chips for now a days? Just the board with chip/program....
- will i severly mess up my braking system if i do a fluid flush w/o using a VAG tool on a car with
- Neuspeed .8 bar or 1.0?? help
- So i washed the car today and snapped some clean pics of the car
- 2000 A4 Cd and Outside Temp Dash inop
- anyone know a good place to order a small fire extinguisher from?
- Under-Engine Cover is a Goner
- What all can go wrong with an ECU?
- barely pulled on an accord v6 from 40mph, sound about right? im only chipped.
- Pics of freshly detailed car (and dog).
- Please Help! Avery loud knocking/rattling was coming from the area of my turbo....
- One of my switchblade style keys won't lock in place when it's open now.....
- PSA: Remember to check your belts on regular intervals!
- My internal locking system is not working..
- tie rod end change
- N112 ETKA
- Anyone have a pic of 18" BBS RS-GT's on a A4?
- New record for a spring install... 1.5 hours!!!!
- something I've noticed re: issue from before
- drivers front window seems to be forgetting its 1 touch up/down sometimes.....
- im about to put 2001 tail lights on a 97, any suggestions before i start?
- 2.8 30V throttle body project has begun
- Dealer said about 5.5 hrs labor for timing belt & water pump job.
- Looking for a 2.8 Need Advice
- best plug wires to get?
- Anyone have a door front door shell for sale?
- Of the mods on your car, did you buy any of them from an AW'er...?
- Power Gaskets. Do they Work?
- TIRE SIZE SUGGESTIONS
- change your own oil, or (a4<>s4)
- Mille Miglia Evo 19x8.5 35mm offset with 235/35/19 for sale !!
- ECU wiring diagram
- S4 Front Bumper Install
- mmm 17"s with 235 RA1's =D
- Have a 1998 1.8t , what are some good Spark plugs? thnks in advance!
- anyone got pics of bbs rgr
- anyone have some 18 inch OZ chrono's they want to sell?
- wat ss kit has the shortest throw?
- Changing Rear Brakes compressing the piston
- Yet another impression of the PES G2 supercharger
- Anyone ever buy/trade a car from Vin Devers in Toledo?
- new shoes!
- Should I Buy This Modded A4...? HONEST OPINIONS PLEASE
- B&M, Nuespeed, Strat which do you guys like best?
- 2.8L Twin Turbo? Check it out!
- Very strange Bose problem
- damage from driving on a leaking heater core
- Buell helmet question
- post pics - oz sl's or flik justice
- i wish i could get my ice>link.....
- what exhaust sounds closest to the thermal r&d
- Rain-X car wash sucks..
- Anyone happen to know how much air pumps go for?
- SIG
- Just picked up a switchblade Key for my 97 a4 1.8T...
- NEED HELP INSTALLING EXTERIOR NEON!
- Locks Broken
- Side Skirts- Where to buy?
- Help with taillights
- Hooray for me...
- speedometer stoped working, need some help
- Cheapest Performance Mod?
- RKA: Do you still have the PCMCIA serial card?
- MY K04 is saweeeeettttt
- Are there any reasons you couldn't put a TT 225 engine in an A4?
- funky starting issue
- floor mats soaking wet and AC is spitting water
- Pulled the trigger on the Pro-Diag. Should have it by Tuesday.
- AW Gods, need some help please
- Is there anyway to get under shifter plate without removing center console?
- Spring upgrade failure
- Anyone from here at the Indy GP ?
- Question on clear corner mod
- Does anyone know the difference between the dunlop SP9000s and SP9090?
- Approximate cost of replacing front pads and rotors? How much were parts, how much labor?
- defective timing belt tensioner
- A4 or coupe quattro
- New pics.. (lot of pics)
- What's the difference between AMU and AEB?
- Aux Input and/or Head Unit Upgrade (long, but thorough)
- omg tire noise argg
- anyone interested in buying 18" oettinger RE with toyo ts1s
- to those of you who have had your headlights stop working
- New wheels
- WTB: pass. side headlight washer cover / lid silver?
- Cleaning Under the Hood?
- cooling problems
- Today's purchase
- My New (Used) A4
- Need feedback on " Meyle Upgraded OE Control Arm & Heavy Duty Tie Rod End Kit W/Hardware"
- DON'T DO BUSINESS WITH THESE GUYS
- drove Paul 858's car tonight. I feel for you DBW people
- Identify this part
- tranny problems....
- head unit!
- Interesting night of oil problems leaves me frustrated and carless
- ACNA-NJ's Third Annual "Firecracker Road Rally" to be held on Saturday, June 26th, 2004
- WIll any of the following hurt my trade in value?
- Steering Wheel Shudder
- Any of you A4 guys want S4 woodgrain trim.....i'll entertain trades
- Bad MAF?
- Car runs like dog **** after a week of storage
- Fog Light Mod: If you leave pin 12 and do the rest of the mod the same way...
- recomended exhaust shops in NJ
- Anybody have their A4 for sale???
- For those of you who put the 17" b6 sport wheels on a b5 question inside please help
- Go or Show: Discuss..
- Did monkeys put on my front plate?
- Are we still all opposed to the huge grille on upcomming models?
- HID aiming questions!!??
- HEre goes my new ride got home to late...
- I need a 12v pulse on key on and another on key off.
- Who know disable the lamp warning when fitted HID?
- 99.5 2.8 TIP Hissing noise.. I found out where its coming from but what is it?
- what's a good front end for our cars...
- exhaust flex joint
- who sells samco hose sets for cheap?
- What cars turn you on?
- any problems with diverter valves?
- I know this will get baleeted, but check the classifeds everyone
- h&r or vogtlands?
- New Audi Procedure on radio code?
- Has anyone retro-fitted HomeLink garage door opener to their car?
- 1.8T may need a new throttle body, or new housing, where can I find one on-line?
- pic of black wire for alarm antenna mod
- Hi, just wondering if anyone remembers the wire gauge size for city light? Thanks.
- Free!! New Waterpump belt to whomever pays shipping on it....
- Posting Etiquette and Such...
- DIY to fix the coolent sensor?
- how to change mirrors
- frustration...
- Old Avant?
- Got me a Concert II AM/FM/CD unit
- replacing a cracked oil pan.. should i try replacing it myself?
- Need to replace my Rear Differential seals
- Day A4ers .. should I buy these wheels.
- Is this right for the k04?
- Anybody wanna trade/sell me their seatbelts, tan/cream for black?????
- I'll search but in the meantime does anyone have any pocketpc installs they wanna show off?
- NOLA/BR GTG tonight meet at the BRCC parking garage
- Every time i start my car, the Stereo...
- Rattling or knocking noises from doors.
- since i cracked my drain bolt for my oil pan... what is the correct amount of torque needed to
- how much does an oil pan replace run at the dealer?
- transmission leaking? how do i check visually?
- Who has installed a new head unit in a 97 before?
- Seatbelt Replacement Q's......
- Website will be down this weekend and e-mail will be affected....
- Which autometer guage should I order with my APR chip? Leaning towards top-right.
- buying an x-chip for my brother. . .
- What do you guys think of this TUrbo Kit??? Garrett
- How long should it take to install an APR Stage III
- Paging BoostTed... buying your old RS4 reps I think. Got some ?'s
- does anyone have a concert II on a 99.5 or up?
- Poll: What's your next mod going to be? and what do you want to see a group buy for?
- those with part guide, can you get me the part number on a 98.5 pass side mirror glass?...
- Cars off... but the coolant gauge rises while off
- x-post from performance and tuning...
- Sunday 20th 12Pm NJ Rutgers GTG!!!!!!!!!!!!!!!!!!
- DAP - had to order more paint.
- Paging Spdrcrpete...you around today?
- Should I get rid of gimpy?
- I noticed while i was in an a6 last night...
- Any problem w/ buying a used exhaust w/ 40k? Any guidance on price on a used Milltek would be appre
- Play in the front suspension
- thoughts about my A4 ( sort of a rant... )
- just got tint done(big pictures)
- Remote Range Mod
- Is the offset on these A6 wheels too much for the a4?
- just installed the milltek exhaust!....
- Audi Calipers!! with Rings.. I want them!!
- I love my A4, wheels, tires, phatnoise and aftermarket HID. That is all.
- Tiptronic mode is gone...magnets?
- Replaced 2 lower front control arms last night. . .
- got my custom fitted APR exhaust installed yesterday, impression...
- diy wheel repair, anyone try, suggestions.
- Stage 3 arrived!!! Pics of kit + track event at Pacific Raceways. (BWW)
- Do you think I could run 14 lbs of boost with....
- Loud groaning noise at cold startup
- ahh all my bulbs are blowing
- How cold is your A/C? Mine is like ice...
- near wreck
- Anyone ever had trouble finding the AC wiring harness? more
- Took car to Audi today. Had a compression test and a leak test done..
- Anyone happen to know the size of the license plate screws...
- how hard is it to replace the alumimum pan that holds the oil
- X-Post from Off-topic, I need good details shop in Bay Area
- just debadged car(sorry for big pictures)
- Should i take this..
- will A8 rotors fit under stock 16" wheels?....
- am i crazy or did i read a post saying our cars run better when its hot.....
- Sad day for me today...
- A4 96 fiber glass fenders
- help...
