- Need help! Is there anyone in the Cary, NC area with a VAG-COM I can use for 5 minutes tonight??
- Pre-order sale on Vogtland Coilovers!
- Fuel indicator and Telephone Jack
- Hey guys.... update on burnt stgIII CM clutch...
- Just started Coilover Install....Snapped a bolt head....Can i pound it out?
- Got pulled over this morning..due state inspection..Cop " you got some killer wheels on this thing"
- having trouble using 1stvw to find W8 belly pan, pointers or suggestions?
- update to wastegate n75 valve problem
- I am off to teh shop to play with my parts........
- Goodbye Avant
- Can someone please help me make a Sig i have a pic and info.
- Has anyone ever converted to auto dimming side mirrors?
- I think someone was pi$$ed off...
- MAF Gone bad?
- A4 Bentley Help
- Question about Key Fob antenna i think i spelled it right?
- Tire Trailer Update - partially finished
- Drunk kills my buddy's Audi. Parting it out now UPDATED
- Can this pop back in or do i need to buy a new one.. (please say pop back in)
- Ahhhh, sweet sweet Big Turbo goodness...... I am in love........
- Can't afford the R8? Next best (or worst) thing...
- Horrible brake squeal... please help!!
- does anybody make a carbon fiber splitter for s4 bumper
- Ahh, another day, another VAG scan. Though this time it was an A6 2.7T
- anybody have online literature about building a 2.0L ABA big turbo engine for their A4?
- My boost is inconsistent from day to day . . .
- What pressure should I be running in 235/40/18x8.5 tire/rim on street/track?
- they're heeeeeeeere
- S4 suspension
- interesting photo found on vortex
- Tie rod ends question
- Fuel Filter Washer PN's...
- Stock one Piece light swap
- RS6 Pedals (for B5.5 Passat)..Will They Fit?
- ABS Speed Sensor Removal
- Fender liner rubbing
- Where is the best place to buy a new timing belt and all of the wonderful cam seals?
- Allroads rock
- brake problem, bumper repair & sludge clean up (99 A4Q)
- Looks like my number came up...
- wastegate stuck closed ??
- PNs needed: 2000 1.8T front brake seal kit and guide bushings
- Where to buy rear camber washer
- Anyone need a seat switch?
- Is there *any* market for a set of pleatheret' grey heated front seats?
- Nice... just scored this little item....
- Window Creaking
- "Lights on" chime stopped working on my '97 1.8T Avant Quattro manual.....
- What does a bellypan cost? looking to buy one for my '00 a4 1.8t
- Driveline Clicking Clunking...Help!
- Anyone know what this symbol means ???
- Technical noob question: I assume front suspension lower control arms aren't same as tierod ends?
- locks, windows and sunroof don't work
- Damn Nissan Factory Workers...
- anyone have plastic battery cover?(plenum cover)2001 B5
- loose accelerater pedle quest
- Happy Birthday!!!! Happy Birthday!!!
- Brian @ avalon: YGM : )
- Cross post-brake pads for a daily driver?
- I want this feature for my car
- Rare Car questions. (x post)
- looking to do s4 to rs4 conversion mod
- *Twitching violently* My APR S3 kit has been shipped... comes tomorrow... no sleep tonight I guess.
- venting: $#@%#!$^!$#%^#$^&$%^!@#$%@#$@! SAIP hose!
- upgrading ECU, do I send the metal box w/ ecu out myself? Does AWE do the upgrade>>>
- Consumer Reports?
- Replacing F120, hood switch sensor
- Sweet! Got a check today from VW of America for $47 for the ignition switch I bought over a year ago
- Ahhhhh yeah, new car.
- If a fuel injector died a code for the injector would come up correct?
- Burnt through a Clutch Masters stgIII clutch in less than 15K...
- TAP Chip Stage 4????
- Anyone w/clear corner mod had probs selling car to dealer & had to put it back to stock?
- Cheap source for crimp clamps/crimpers: irrigation supply stores...
- Maybe it's just me, but
- New the Board with AUDI Question for those who know their cars very well..
- Avalon is proud to offer JH Motorsports short shifters..
- Used or not Used??
- LOL - Stealer wanted $130 for an alignment..
- So here is to hoping my turn signals work for a 2:30 state inspection.. damn hazard switch
- Monday Replay: Introducing our newest tranny mount!
- how to adjust backlight of the dash
- ETKA guys...
- cruise control help
- part needed
- Just figured I'd share... project 4000 turbo swap is officially boosting!
- Found a good site for referencing oil filters... thought Id share...
- 8D0201218B, fuel line feed that connects to the "out" end of the fuel filter
- VVME HIDs installed.
- Which TRE's should I get from PureMS? Meyle heavy duty or Febi-Bilstein. Thanks.
- Just a PSA/Rminider... Check your control arms.....
- PAC: YGM
- 97 A4Q P1504 CEL code Vaccum plate Picture ayone? It's driving me crazy HELP
- Who owns this beauty?
- Two weeks from its 10th birthday...my A4 won't start. I am stumped and looking for ideas.
- Attempted Hi-Beam fix gets interesting....Now Highs come on w/ Right Turn Signal...
- Buying new radiator
- I just bought an audi need some help plz
- Sad Day
- Ok need some answers before I go yell at Audi
- Photo with airbag out....electrical anomaly
- n75 valve open circuit code and car is over boost
- Last ARX thing....drive easy while going through process or normally?.....
- Meh, procrastination in school has led me to do the following.. thanks justdave!
- stupid noob question.....I'm going to go ahead and assume
- blog #4: It is in...gotta order more parts. (light edits)
- I just wanted to contribute my baby
- Oil leak 2.8L
- And.. She's Home!
- My A4 if anyone cares to look
- ETOS Setup
- parts still needed x-post to classifieds
- A few pics from St. Pete Grandprix on Saturday...
- What's the recommended ft/lbs on the rod bearing bolts on 2.8L (AHA)?
- Fix your flow! Quick possible fix for you guys thowing PO411
- Who has the cheapest wheel bearings? Thanks
- HELP! Can't get rear caliper off
- Uneven brake pad wear??? (questions inside)
- Who needs a new CV boot? I do. Axel replacement is best bet then right?
- Will these work?
- Exhaust Tips?
- 2001 a4 1.8t Transmission update and opinion needed
- This is the Bentley manual I want, right?
- is the 2.8/S4 belly pan same as 1.8t or can they be fitted onto?
- Can anybody help me out in finding the repair kit for the coilpack wires?
- Paint suggestions
- my non AWer friend needs a new exhaust for his b5 2.8, clips of your exhaust and specs please...
- overheating '96 CAb 2.8L Thermostat? waterpump?
- anyone have tips/suggestions on speakers...
- Went to the NY Rally yesterday...took a few crappy pictures
- : gets aggravated: I'll now take black, too, please.
- K03 sounds like fingernails on a chalkboard, Now What?
- Do I have a freakin' chance of this not rubbing?
- A4 1.8t in Memphis.....I think I know who you are
- I looked at a few pictures of my car before I wrecked it. I was/am upset.... Why is Silver SOO
- OK...I'm Auto-Rx'ing. Is this link accurate as far as procedure? Why...
- Doing springs/shocks on my a4. Should I replace the strut mounts too? (I'm at 85k miles)
- Has anyone had the Bilstein R-2000 used on their 1.8?
- Hey whats up guys been a few weeks sence i stopped in. got a few questions about some codes
- Next bang for buck upgrade
- Used hid question......
- old school
- AB<-- awesome blog... ordered S4 bumper... thought "thrifty" this time
- Just pulled the trigger on a shiny new laptop, you know what that means now.
- FB: slow progress
- So... Does the Borla exhaust REALLY give +15HP or is that like the claim K&N gives you +5-10HP?
- and... I R&Rd the wheel well attachments on the belly pan.
- oh yeah, and I also reinstalled my RS4 grille and did a full oil change.
- just finished installing the drivers side tranny mount...urethane filled.
- Does anybody know the part number(s) for the wires that run to the coilpacks?
- my car must be getting old.....
- ETKA online ... if you can read Russian ;-)
- No more Airbag light staring me in the face, ahh life is good.
- Does anyone have an OZ superleggra center cap they want to sell?
- well, minus 1 more B5....my brother was rearended last night on 95 in ma...
- NE1 know of a local source for coil packs in North Jersey?? Bergen County
- Bought the Duralast Today
- How bad is Lugging engine? 10 mph in 3rd gear and when start
- Anyone replace a fuel pump on an A4 before? Tech instructions won't quite work. Removing pump...
- So I installed my salvaged cluster today and it started off...
- So... How does my valvetrain look? Also, anyone know how to do the cam tensioner gasket?
- Car Alarm...
- Will this work to change the rear wheel bearing on my car?
- edit* If it isn't my coilpacks or spark plugs, and I don't have a ignition control module
- A400: Here is the best picture of the collector that I could get:
- Cam Chain Tensioner Question - Pictures Inside
- Stripped lug bolt: Can I drive my car?
- Poll: Who has relocated their battery to the trunk? Where exactly in the trunk? Fun job?
- Why are these bushings so god dam expensive 58 stealership and 37 online (shipping included)
- weird fuel gauge/miles left issue
- Hazard Relay Repair Help
- Can someone explain the wires in the fuel tank and it not blowing up? I am replacing my fuel pump .
- Big thanks to Carson for the care package!
- Does anybody live around Bloomingdale, NJ who has a VAG-COM?
- So dos anyone have an idea what this code means ...
- I need new MAF but my intake was modified by PO
- BA9S LED Bulbs
- Wishbone failure...
- What are some good do's and dont's for going with a custom exhaust?
- Thank you PureMS and andysprague. Money well spent
- Car is having Radiator fan problems
- Those with a Fumoto drain valve on 1.8T...I need help
- Just how rare is this car? (Brilliant Yellow Avant)
- Does anyone have an extra used/new rear wheel/abs sensor for a quattro B5.
- Tranny fluid/filter change: In case anyone is wondering, there are no obstructed screws ...
- Boost probs continue?
- I need a better camera, exhaust clip ... with TP in
- Are OEM flywheel bolts the same size/length for an Unorthodox Racing lightweight fly?
- 1.8T NON Quattro rear rotors help
- anyone with Greddy FMIC have pic of where it sits?! mine is really high and I want to drop it down
- need help on a part #
- The Audi R8 on display at Audi Forum NYC has an ignition problem
- Anyone ever gotten headlight warning indicator, butt ALL lights working fine? Is there a fix?
- KO3S or KO3
- Is the journal bearing in
- More problems, I tried doing musical coil packs and still cylinder 2 is misfiring.
- updt: failed emissions, can someone help me with these codes? cost of parts?
- AWE-Center Vent Boost Gauge Falling
- Replacing SS Brake lines Which size flair wrench?
- Anyone have the part numbers for the cam tensioner seal and plug?
- Hey DungBeetle or anyone else am I supposed to pull the coilpack apart?
- breather tube. isat-wrench though, 232-mile tow to scotia?
- Pics of the car
- Weekend Mod/Maintenance Thread
- Truly Weird Clunk
- Cam tensioner seals and plug? Is there a writeup? Might try this today while doing my valve cover.
- Friday Picture:
- I've been told that quattro steering knuckles from a 2.8 do not fit the 1.8t
- No Boost???
- my next bumper...
- Using 108mm flanges in rear diff
- got a question about tuning?
- can someone confirm. When replacing hazard switch, gently pry the trim piece off right?!
- Replacing fuel pump: Can I use standard hose clamps or have to use crimp clamps?...
- Paging Modifieda4 and other k04 people... having a boost issue
- Anyone have 2001 OEM sport suspension front shock lying around?! Used is fine.
- Doing valve cover gasket tomorrow, what should i use to clean?
- It is possible to have faulty spark plugs right? Tons of them?
- For those who do their brakes the hex that holds that carrier/rotor is a 7mm front and 8mm back?
- Nate and etka pros...
- Got another box today (warning camera phone pictures inside)
- Slipping Tiptronic Problem Solved
- Introducing our newest product!
- Getting Screwed by the Audi dealership.. Your thoughts?
- You guys are gonna hate this idea. front shock is blown, I have no money to fix it.
- some abbreviation explanations??
- Im pretty sure my F/R caliper is sticking. Constant faint scrapping noise. Shhhh. Remedy?.....
- Whats the difference between the 2 tranny mounts 034 offers?
- BG Injection System Cleaner - how do you use this.
- Horay! My new exhaust arrives on Tuesday and my Motive power bleeder arrives Wednesday.
- Helluva time getting drivers TRE off..
- my audi completed 100k (99 A4Q) & how can
- Why the fvck are those stupid little check valves ( 058-905-291 ) so expensive?
- What are these parts worth?/Paging Andy S
- anyone ever replace their power steering pump?
- I destroyed my C-Pillar Panel
- KEY PROGRAMMING HELP!
- Being taken for a ride by the dealer? And not in a new car...
- PSA - Carquest Gold Oil Filters are made by WIX...
- suspension?
- Haha, yeah this dudes a ballar...
- Does it matter if used wheels are marked when they come off
- PSA: pre-cat O2 sensor for ATW Jetta from ECS Tuning does NOT plug-n-play with ATW A4 1.8T
- A4 1.8T Lifters
- Its like they say "if its too good to be true then it prob is"
- any one know what a MAF should run me and if theres any
- FB: Long Block
- Anyone have pics of BBS RX (or even BBS CH) wheels on a Hibiscus red A4? I did STFA but no luck.
- Non Audi Engine Conversion
- Hit 100,000 miles - crappy phone pic., suggestions for maintenance?
