- Anyone need a flywheel?
- google video sucks!!!
- Is anyone running a boost machine on a b5? Just curious...
- Anybody get anything from UPS/DHL/Fedex/US Postal/etc.
- Dyno results are back!
- Kris please come back...I can't take this anymore....
- BOV's are baaaaad
- Part number for the Central Locking System pump? Do VW Pumps work on the A4?
- In all seriousness, I sure hope Kris wasn't called away on any emergencies.
- this has quickly become better than AWOT.
- 13 YEAR OLD HARDCORE SCENE inside...(MWW)
- To all those people that participated in the Ecode Test Pipe Buy that need non foulers
- This no mods here today thing is cool. I wish I could think of a rule to break... ;P
- Short Block Question... Does anyone know if the short block from an 03-04 1.8T Passat can be used...
- How to remove/install bumper wrap?
- Questions about test pipe.....please offer advice
- What would you expect to pay for a set of BBS CH....
- How to permanetly get rid of rust on the brake rotors?
- Anyone have these on their car yet? just saw em at edge racing and am interested...
- Tyrolsport UG SMIC installed...
- Which tires worn faster, front or rear? I have FWD...
- Need some additional help...
- How is it that the J31 boosts so much higher than the PC-16?
- What do you think your next new car purchase will be?
- Co-worker's A6 2.7T just diagnosed w/ water pump failure at 60K...
- rear defroster question
- 96 A4 q part needed for interior
- Weekend brake job
- now the amsoil 5w-40 euro oil is sayin it passes MB 229.51 and bmw LL-04 they never stated that b4
- 1996 A4 2.8 chip upgrade?
- Rattling and clicking noise from front brake assembly FIXED
- Zimmerman drilled rotors on a 97 2.8q
- ABS blinking light comes on once in a while
- 2001 a4 Mirrors
- Does ETKA list part #'s or sizes for fasteners?
- Anyone put the VW single-blade wipers on the A4/S4?
- 18 wheel torque specs
- been searching for a faq for engine mount replacement anyone have a link for one?
- Quick N75 answer needed...
- "..a Ferrari hit the power pole....the engine is on the road way..." (in LA) both me and .....
- bimmerparts timing belt? I need two sets and $514 shipped doesn't sound bad.
- Problem with Symphony stereo deck. At every startup, goes to equalizer setting. Please Help!
- Ordered ecodes from AWE. :) Too bad they're in PA. %6 tax. then again I might get them by Friday :)
- test
- What the f*ck??
- What ever happened to Big Nipper? Did he finish his A4?
- repost for weekday crowd: online CAPS calculator up and running...
- Neutral Safety Switch( Mulit Function)
- Double Din Unit for my audi
- Can gear oil/additive help mute the pitted 1st gear noise?
- I can't believe someone bought this jury rigged piece of crap for $20k Can
- help my a4 is a pos....
- who wants to "chip" in and get a better-than-PC16 tune for our
- supposed 446awhp 1.8t
- Maine GTG
- Alternate Radio Removal Tool....... JigSaw Blade
- hey starting...
- ecs fpr question
- Serp Belt Tensioner Replacement??
- A4 Quattro fuel filter change
- timing belt tensioner failure, help needed
- OH NOES!!!!11!!!
- Found an ECU ending in 557 P, and as far as i can tell it should fit my car 98.5 1.8T 5 speed, .....
- To people who replaced their clutch with 80k + miles on the car
- what do you guys think of a 99 Passat
- this *IS* a total waste of money, right?
- if any body needs a front control arm...
- I need a licence plate frame...
- Perrin End Links install; (bandwidth warning) *imgaes resized*
- Suggestions for Audi A4 Cat-Back Exhaust System
- Any Lawyers here?
- Beginning mods 30v stack and MAF ,bellmouth cut on lathe, came home today.
- Will the EVO FMIC fit behind the stock bumper w/ trimming? Or is the S4 bumper necessary?
- Need Good Repair shop. Dealer Prices Just too $$$$$
- Everything is off the car and ready to go!
- Anything wrong with running 19" wheels in the front and 15" wheels in the rear?
- Problem solved... Anyone know were to buy OEM engine cover?
- What does this warning light mean?
- Audi Cat-Back System
- $1500 to burn at home depot on tools. What do I get?
- Any worries putting back in my old K03 that's been sitting since 2000? I yanked it out to (more)
- BSK... this is for you
- Is there an ignition only power supply outside of the interior?
- 2000 Audi A4 1.8t radio removal and replacement
- oem rs4 mesh....i cant seem to find it anywhere...
- do aftermarket crank pulleys deliver more performance at all? i know some JDM owners who say they
- Does this look legit?
- Paging BSK...Is this shifter like your's?
- H-Sports=good. I just got them installed. Everything else I found out=bad.
- Xpost: iCruze by Monster now $99
- ONE MORE TIME <<<ripped off in the classifieds>>>
- Anyone know the exact parts required to use Allroad or RS4 transmission mounts with 2001 2.8 manual?
- Acceleration/clutch issue
- Cimate Control buzzing Fan issue: Cost to fix? DIY?
- Poll: who mounts their tires every year or have separate wheels/tires for winter.
- Door Lock Problems
- 01 A4 lower door trim install
- Ok after annoying everyone on audiworld with vag-com questions
- Noisy Radiator Fan (electric)
- who on here wanted the updated tail lights from 99.5 or newer.. email me
- has anyone ordered this control arm kit?
- Anyone need a light gray leatherette rear seat?
- 99.5 A4 concert HU to symphony HU
- Final total of all parts .. from oct 2004 till feb 15th = 6734.80 . includes one timing belt change
- I need some help from one of the Tiptronic guys...
- drivers seat vinyl cracked on my 01 Avant, do they sel just the bottom piece?
- Repost from Sunday - HVAC Fan Squeaking - Need some advice
- so it seems I need Tigger's motivation to get these things installed
- Charging system problem... Advice?
- Brake Mods Complete (figured it out, fixed "X"s)
- Instrument Cluster swap from Trip to non-Trip
- What is wrong with my car today?
- Question of the morning: Is the S4/S6/S8 front lower (load bearing) control arm beefier than A4?
- Air Intakes
- Head Shielding gurus...
- ModifiedA4 - Brake squeak is gone - thanks!
- NGK BKR6E's suckkkkk
- steamy exhuast
- (noob question) sorry for asking all these retarded questions but has anyone installed a short shift
- La Jolla GTG Thurs, 2/23 7pm, Rock Bottom
- Changing the O2 sensors...
- My driving skills are good on road....
- Cold tepms, car won't start, need help ASAP, need to get back to school.
- Door Lock Problems....yes I have searched
- TRE, TT install, ECT sensor = semi-productive weekend...but what to use to stick TT on knee bolster?
- Does anyone know how many volts it takes for the radio to retain the code?--->>
- Anyone know how hard it is to replace the combi (or Kombi) valves on a 2.8?
- Neuspeed...
- looks like another poor soul w/ PC-16 came up short on the dyno
- P0150 - anyone know which o2 sensor is b2 s1?
- bitjockey - did you try the 5 bar fpr and stock injectors?
- wheels..
- which chip is the best ?
- is GIAC X really worth the extra $210- at about $495??? over a NEUSPEED 1.1bar?
- Audi A4 2.8 99
- a nice clutch change video
- stock injector difference between 99.5 and 01.5 1.8t?
- Still playing around with the vag-com non stop its alot of fun but ...
- Cell Phone Mount/charger?
- wow this is slightly OT but a vw transporter van with a porsche 993 engine conversion..
- Shipped my summer wheels (OEM RS4 REP's on the 01.5's) yesterday...Guess the weight w/ rubber on to!
- one of our tech article writer seems to be drinking while on the job
- what happens if main relay is bad.
- broken motor mounts do NOT necessarily leak (you gotta see this pic)
- Any bets on Daytona?
- I figured out how to do the things im lookin to on the vag-com but ...
- Where to get porsche monoblock calipers for cheap?
- A4 suspension help/question
- Good source for OEM Rim: 1998 16" 7 spoke "sport" rim
- 40K invested into this a4???? must be a joke
- turbospeed(near danbury)
- tech section got some b5 articles added over this weekend. take a look guys (and girls)
- you can only use the v512.1 vag-com w/ a ross tech cable correct?
- Im trying to figure out what might have caused this to happen???
- cant get my brake pad sensor warning to go off w/ vag-com
- hmm hope i dont get yelled at for this..
- I spent all of this money to make my Audi happy, but it's now sad again...........
- Needing some help with noise at Higher RPM and acceleration pleazze.
- front passenger door pin switch part #? is it available separately?
- How much do you guys pay for a bottle of Mobil 1 0w40...?
- Are there differences between CD changers across different model years or between A4s and S4s?
- Power loss between about 4k and 5k..
- weekend PSA: web based CAPS calculator up and running...
- PSA: Flush your steering fluid every 50k - i did at 52k and
- HVAC Fan making squeaky noises... Need some advice
- Bottom Clips?
- retrofitting b6 rearview mirror (compass) into 97 b5 w/o anti-dazzle help
- Hello All
- Ecodes are the best thing ever. I dwarfed every other car I saw tonight in light output
- another noob question
- Anyone know what a good aftermarket Exhaust Kit for a b5 2.8 would be? Greddy? Militek? Borla?
- hvac system stopped "cycling" from middle hvac ducts to feet hvac ducts
- Brake Lights = WTF !!
- just totaled all my receipts for mods done to the car... 4620.63.. not including c/o's
- Mmm...brakes! (warning....to the camera g*d's...I am the digital SLR NOOB!!!)
- Boost leak maybe? help!!!!
- clutch photos... no write up coming sorry folks, hands way too dirty to take photos through whole
- Universal AFPR...
- removal and replacement of doorlock pump + comfort module
- Velocity stack for 30v found ,sorta...
- my oil change this morning sucked. but the day at PureMS was better :)
- part # for little screw that holds the 97 a4 lower front door (outer) molding?
- front pass door lock/rod problem on 97 a4 (long)
- powdercoat wheels?
- HELP!!!! ashtray removal!
- Cannot connect with ECU
- wow the FAQ turned 40K today
- Went for a little play in the snow today
- hey guys just got the vag-com all set up and ready to go ...
- hit/skip....
- After about 15 hours my turbo is installed and timing is finally right...i am happy..car is fast
- any wiper blade recommendations?
- Question on my headlights, they came with the car, i want to get hid's and i dont know if these will
- I need a failed ABS 5.3 controler. (nonworking)
- Good friend is rebuilding a '99 1.8T after a TB failure... anyone have a decent head lying around?
- drivers side mirror vibrates
- So i guess I'm ****ed? Messed up my timing bad? No idea
- Should I put a snub mount in 01 2.8?
- Hey guys...what are your thoughts on xenon high beams??
- How to Reset the Service Interval Light (for 1999.5 A4 2.8 v30) ?
- So I ordered new fender audi logos from the stealership last night, and they are $30 a piece!
- neuspeed 1.1bar on a 2001. should i go for 4bar fpr? and/or different N75?
- Help with maintenance interval !!
- Finally gave my car her chin.
- yes please
- some cool new pics taken while i was out cruising with some friends tonight
- EGR cleaning
- So I replaced my dead lower door trim ($21@stealer) -->Poll: paint lowers this weekend?
- car had to be left on the side of the road tonight
- electrical nightmare (power locks..windows..sunroof and keyless all dead)
- tiptronic error -- switches to auto
- Lisle CV Joint Plier Tool Review
- Can someone tell me what this is?
- Dumped out the Royal Purple Max gear in my tranny, flushed and filled with Amsoil GL4---->long...
- clutch is in, (delivered) and will hopefully go in this weekend ;) BWW
- Should I buy a TCU?
- This seems like a good price, what do you think....
- What blocks should I use on a vag-com to check which cylinders are misfiring on a 98 1.8T? (more)
- I think I bought a fake Quattro
- Best $200 I ever spent
- So the turbo is installed...i have to install the 5 bar fpr, ecu tomorrow, and my timing is way off
- Final pics of my car... and the conclusion to my story...
- Blinkers stop working occasionally, I need to verify that I have this correct...
- no service engine light when key is turned to on position
- cam seals tool?
- Fun weekend planned for me yffs. See ya'll sunday night!
- Poll: How often do you have to change your foglight bulbs? And how often do you use them?
- my computer isnt loading ATP's website, can someone please give me their phone number
- -7 Degrees here in MPLS....
- for all of you that love cars, and hate to pay for the premium gas that goes into them...
- Phatnoise on a 06?
- Anyone have any suggestions on chipping? apr? and I have heard of giac ones too?
- lol, leave it to poortex to have a ghetto fast
- could a bad n75 be the cause of my 5psi boost loss?
- Belly pan?
- Lot of surging when cold this morning. N75 going? 132K with original N75.
- Car = Total loss... final tally 12,000$ ... ummm time for an s ?
- Sorry about the 2003 blowup post-wrong forum - it's been that way the last few days!
- Padding on armrest broken off.
- My 2003 A4 threw a rod yesterday-total engine destruction
- Anyone have any suggestions on spark plugs? Iridium? and I have heard of lazertip ones too?
- HID Conversion Question.
- vdo boost gauge question
- Pics from our recent Pines to Palms Drive
- Does anyone have any ecode shipping plugs?
- OT: Go figure. Last week paid $170 for a set of used Valeo's. Today paid $17 for a new set.
- Decided on Silver calipers b/c of AndySpragues work on his calipers...
- Phil: what's the part no for this?
- Just added interior space to the avant
- Wheel bearing tools HubShark or HubTamer
