- G35 or Acura TL/TSX
- blow off vale..?
- Follow up to yesterday - removing cams and lifters
- 1998 a4 1.8t quattro
- Installed a FMIC and have a 2 psi drop - should I get a mbc and give it a bit more boost
- Any other hints on removing upper control arm bolts?
- 2000 A4 - digital display on dash burnt out - warning light coming up... help?
- A/C Problem
- Attempted to bleed brakes and reservoir cracked...
- Oil leaking
- Who else has had to relay their VVME HID kit? (headlight warning indicator fix inside)
- HELP!!! Got another A4 and dove into window motor/regulator problem...
- Bad ECU?
- Clutch Plate Change
- Clutch Change
- Got the head off the motor and it aint pretty
- Brakes make a "sucking sound" when released...
- Need opinions on lifters - trying to fix a tapping sound from the driver's side head
- kevin at ECM, you still sell parts?
- What code would be thrown for a bad coil pack
- Dungbeatle! Lookin for boat parts... Email or AIM? sorry...OT but prob the best place to find ya.
- diagnostic question: these data readings point to a bad MAF?
- FB: Engine is out
- APR R1 better than the turbo XS?
- just put a T$)(*^T)($#*^(#UJG screw indent into the bmw's was-perfect bumper what do i do!
- How can I center my steering wheel?!
- Engine Overheating . . . need advice. . .
- looking for - coilovers / DTS used
- Car is feeling SO sluggish... And I just did a bunch of stuff to it...
- Anyone have pics of a broken timing belt/dented pistons/valves
- What to fill my sunroof hole with this weekend?
- Carson: How much are the little plastic pieces that go around the fog lights?
- Where to get my exhaust mani ported and polished and how much are people charging
- programmed 2 fob key opens closes doors wont start car
- About to purchase 98.5 2.8, window regulator/motor question.
- Pzero leaks
- My new 18's are on!
- Need ETKA lookup on door handle switch again
- poll: who has the most quiet performance exhaust on the market?
- HELP!! Rough idle blinking CEL.. car still runs but like sh*t
- I didn't run as well as I had hoped at Raceway Park tonight, but I had a helluva good time
- FB: Let the swap begin.
- found a use for all my cooked turbos...
- Are there any PureMS promo/coupon codes I should be aware of?
- Is my coolant temperature sensor failing?
- mika software question...inside...
- Are RMSs known to go bad on the 1.8Ts?
- Real crank shaft seal might be bad. Is it better to take engine off or tranny off ?
- what the deuce? this can't be right.
- Center Display Not Showing Doors Open
- Aftermarket clutch
- How do you get the center console piece out over the ebrake? I'm stuck
- from loxx0050's post below... it appears that Ksport also lists coilovers for $1200 that offer
- Well im back... Does anyone in CT/Western Mass have a compression tester i can borrow?
- Big Brake Kit - K Sport???
- Does anyone a small piece of .25" aluminum plate laying around?
- thanks audiworld- faq rocks, members knowledge is great
- Throttle Body Fault Codes on 1999.5 2.8L Tiptronic
- Audi A4 Fuel Gauge Malfunctions
- Hmmm.... To make the white instrument cluster red or not... that is the question.
- Need some clutch wisdom.... (STFA) thinking about Southbend...
- I need to learn how to make carbon fiber molds... there is no good intake for big turbos
- Power Steering pump was wrong one
- Need a part #
- This ATW ECU didn't sell for us on eBay at a $300 starting price with no reserve.
- Those curious about DIY precut window tint. I got response from them about the size etc.
- ZOMFG its back again
- Happy Birthday! a look at the a4 through the ages
- Pretty sure my temp problem is the sensor.
- If I were to swap out an axle, what would I watch for....
- Posting for friend : Arent there a few common Radio unlock codes that we all share?
- v30 2.8 intermittent problem - crank but no start
- Wanted to buy: Factory 1.8T FWD exhaust
- Air bag question (little long)
- DIY Problems With a Black 2001 a4 2.8q
- Audi / VW PR Option Code Search
- So what roof cargo boxes are preferred for non avant owners? I have a Thule rack.
- Rear stress bar for our cars?
- Selling my 98.5 2.8 Frontrak 5 speed need price advice
- Getting ready to replace my water pump seal that is leaking, should I
- My check engine light keeps going on... and then off... and then on
- ughhh clutch is slipping, and its only been in there for roughly 18-20K....
- Blkpearl: did you change your eibachs/bilstein sports because they "wore out'?
- help me out... is this a good deal?
- 98 A$ headlamp
- nOOb q: How do I switch coil packs to test intermittent misfire? Water pump running after shutdown?
- guys i need help diagnosing fathers car problem...
- any one has a good graph/numbers (with no boost leaks) from
- Tranny doesnt matter if i buy a used chipped ECU right?
- with H&R coilovers can u set the back height higher than or equal to stock sport?
- Anyone know how to take off the center console panel?
- Stg 3 B5 vs. 335i
- Need Help ! ! RPM surge in reverse gear...
- After seeing Kris Hansen's post about greasing the CA's ...
- What valve is this on top of the airbox? It makes a rattle noise- 99.5 1.8TQM
- Weekend Mod/Maint thread...
- Update: K04 Upgrade
- Looking for advice on '98 Avant with A/C failure
- One of my auto dimming mirrors went bad...Anyone try m3 look a like mirrors?
- Help me interpret fuel pressure readings....
- Opinions please. Purchasing either a B5 or B6 avant. details follow
- Punk kids!! Stole my wheel lug-nut cover...
- NE1 got the top of the arm rest for sale? (Black leather)
- So I've got a 98 A4 1.8T QM, what kind of ECU am I? I want to get a "chip" but what is correct box?
- Uh oh, someone just bought a T28 & manifold. Anyone ever run a T28 with PC16 software?
- Does anyone know of a good source for replacement H7 HID bulbs like this?....
- Lookin for a rear seat...
- So i'm thinking about rebuilding a blown aeb
- can't seem to reprogram keys
- Can I trust Jiffy Lube for coolant flush as long as i watch them do it?
- Spring Cleaning Sale!
- Proper battery for 96 A4 key remote?
- Anyone have these wheels on their B5? I believe they are B6S4 cabrio wheels.
- 2.0T impressions:
- Does it matter if I replace a 2 button FOB with a 3 button version on a 99.5 B5?
- Some shots of the car pretty clean and of the A! Avantgarde skirts on...
- Just installed Windows Vista on my Macbook Pro and VAG com starts right up!! Anyone want the old PC?
- Girlfriend made me a new sig (now cropped)
- Service Light Came on, How do i turn it off......
- Power Steering pump - my card had the "wrong" version installed
- Bent Rim Question
- Anyone parting out a 98 or 99 tiptronic A4? I'm looking for....
- PSA, AutoZone has 5q of German Syntec 0w-30 and a jumbo BOSCH #3500 Premium filter on sale for $25.
- Radiator Replacement...dealership rant.
- Can someone give me the full part # for teh 710n DV?? I need to p/u one..
- Glad to see I didn't miss anything over the past couple of days other then the same ol', same ol'
- Toasty Buns! Now that summer is here the driver's seat heater has decided to stay on.
- My new TOYS - I can't even go to sleep!
- Paging *Audi Junkie* - All I found at wal-mart was thick stuff
- radio has "safe" displayed
- anyone who's replaced their driver's rear abs sensor, where does the 2nd metal clip go?
- missing air intake clip. quick fix suggestions
- question for all you part number gurus - central locking pump
- Tyre Poll !!!! P6000's finaly dead. Just got some Goodyear HydraGrip. Any views???
- 2004 A4 1.8T - About to buy - Any Advice
- Going BT what are the most essential gauges to have to monitor the life of the car.
- OT: anybody here with a gixxer600 and hopefully power commander?
- oil anyone?
- Vogtland coilover owners: Did anybody actually change the front springs with
- Fun question: What do you think the dealership will quote me for my car's squeaky front end?
- newbie question
- difference "k" vs "E" Cam chain tensioner
- Clutch job on 2.8 1999.
- no luck on suspenion noise
- Stiff steering at idle
- A Parody Question: Why would someone have to explain the "type" of question they are asking :)
- dont post much here anymore - anyone currently parting?
- LaBree high flow cat
- a vag-com graph from a log back in january...
- A theoretical question: The BPV system...
- A practical question: What's the best way to go about fixing a coolant leak?
- Clutch is going, should I go with a LWFW too or just do a new clutch.
- Oil Pressure light goes on and tach simultaneously dies.... I've STF, seen it posted but no fixs???
- receiver drier replacement part help
- Morning Guys, Auto Tranny ; when coming to a stop , who get the 5mph "KICK" ? Thinking sisters
- Car will not go into "park"
- fact or fiction?
- Injector question
- I am such a newbie at all this stuff... i need some 1.8t veterans to help me out...
- OT.... I don't care...
- Does $150 a wheel sound high for stripping and powder coating black?
- $1495 for STaSIS Tracksports
- Upgrading to 255 walbro fuel pump
- Low Oil Pressure light comes on intermittently.
- Aparently I'm SOL on a replacement
- 99.5 A4 1.8T will not go into park. Help!!!
- Looking down VVVV at Starting's post... who would be interested in a group buy for "034" clutch/FW.
- whoah, sweet! Someone left a case of beer at the front doorstep!
- Just pulled the trigger on the 034 motorsports clutch kit...Little grad gift for myself
- long shot: Santa Clara University A4 Silver, painted lowers, 6 spoke rims, aftermarket exhaust etc.
- AWE K04 kit exhaust question?
- Security alarm goes off by itself
- steering issues
- Window Tinting
- STaSIS Engineering B5 Memorial Day Sales Event... (x-post)
- Does anyone know what
- Waiting for my car to get done at the shop, doing some more reading up on alignments and
- Coolant smell inside the car when cold, also oil burning smell.
- PN# for trim plate to which shift boot attaches - gray 2001 A4 1.8TQ manual and best source? thx
- Greetings: Just picked up a B5 A4 project, have a couple C4 A6 daily drivers.
- Spark plug reccomendations?
- APR Releases the R1 Diverter Valve!
- Does anyone know what's involved to remove the exhaust in one piece?
- Sooooo, the ECS light weight crank pulley kits?
- well added another a4 to the mix.
- Front suspension part numbers
- Anyone ever try these?
- Does anyone have, or know where I can get, the top right button on an '00+ stock head unit?
- Does anybody have 1 extra celebration center cap? Or know where I can get one? Thanks.
- What engine code does this valve cover fit? And what years was it used?
- rough idle from a cold start.
- Fog light question...
- So getting my first roof rack, tired of trunking my crap....FAIRING question, best size?
- theoretically, which would make more power? GIAC-X, K03 and stock cat OR stock ECU, K04 and TP?
- Quick Question
- 5.84 CAPS run last night in 63F, 50% humidity. Damn, my 17s were really slowing my times down
- Does anyone know the part # for the motion detector button??
- Crap... I overbuffed with the polishing compound to get some crap off the paint...
- vag'd my car and after some searching i think i have to replace my MAF..
- Question about Adding Coolant (off-brand) and above max.
- boost problems continue!!!...please read
- B5 1.8T Flex Pipe | Downpipe replacement writeup | Repair options | Flex busted
- I REALLY hate those small vac line clamps... Broke some junk and need part #'s...
- Service Oil Light is On
- can I install oem S4 B5 injectors and airbox on a A4 B5 2.8?
- Slight ticking after putting different wheels on. Wheels are 18x8 and I ran them on last A4 no prob
- Driver side door (cylinder) lock advice.....
- alex kassel YGM
- what's a realistic selling price for a ndbw k04 giac ecu, k04 turbo with about 10k, fpr, and samco?
- where to buy central locking pump?
- I wanted to introduce the A4 forum officially to my A4...
- What should a stock chipped A4 1.8t due in a quarter????
- PAGING wonderful AW sponsors (and members) - I need a set of Cat-Converters for a customers 2.8
- suspension noise
- Need help with brake issue
- Air come in
- Is taking the front bumper off a right of passage for Audi guys?
- best way to find a slow coolant leak?
- Getting an alignment done tomorrow, thinking about going 0 toe F/R....
- Thank you PureMS! (and mike for all of his help)
- Need a part number. (I found what was making that racket)
- found the culprit to my oil leak...what is this? pic inside
- Water leak through A B C & D Pillars?
- Molybedanum (that's what it sounds like anyway)
- Interesting discussion regarding use of diesel motor oil...
- About to have tires mounted, after looking around I think i've decided Walmart is the place to go..
- What's maintenace like after 56k miles?
- Recommended Gasoline
- From what I understand, these are a hot item...OZ SLs, good price, craigslist (not mine)
- strange thought: would anyone like an all expenses paid trip to the yukon?
- How many people really replace all belts and hoses every 4 years?
- Stuck... Doing oxygen sensors...
- WOW (seafoam)...
- So It goes: head to come off in a week but so far the wheels are turning
- tranny gone, help with swap.
- heater control buttons-pop off?
- Where can I tap into a power source that has power only until the door opens?
- Any DIY/writeup on removing the Oil Pan?
- Smoke at the gasket before the catalytic converter while seafoaming
- Overboost on stock A4 1.8 - more confused than before
- Check engine light diagnosis?
- Right front Bilstein is making some sort of "popping" noise on rebound -- any ideas?
- The phatbox doesn't display track name on the trip odo, right?
- I've had this itch for a while and it just won't go away
- Sweet deal........ this one comes with a "XTD Racing" window sticker!!
- I can feel my engine shake sometime during stops (at idle) - is it time for some new motor mounts
- got the high flow cat in, but not all is good in my world
- Great Video
- serious k04 problems,
