- Revo Technik's 'Two Week Tune-Up' sale begins this Sunday at H20 International!
- Looking for avant cargo-area side panels
- any thoughts on sending my cluster to bba-reman to fix trip computer?
- Floor Mat Replacement/Part # inquiry...
- Got Brakes!
- Oil pressure questions-strange
- Hit or Skip: RS4 Wheels... Will they fit w/o rubbing?
- Fuel gauge problem
- Need a new FW to match to a new clutch, looking DMFW but lighter then stock? What are my options/
- Opinions please. new vogtland coils, or new mounts all around. Thnx
- Got a couple more errands to run and get food to stuff the cooler but I'm OFF to Maryland!
- Febi Bilstein or Meyle control arm kits?
- another small story why dealership service sucks.
- Ha!
- FYI Guys, I won't be around during the day till Tuesday
- anyone know where to source a non-mangled awm valve cover?
- what the deuce?
- Anyone running Alcons? F and R?
- Engine hiccup at 2.7K RPM and full boost
- looking to get a remote key
- anyone have a driver side abs sensor?
- FB: Thanks Joe!
- Ducktape - removing without paint damage?
- Coolant leak - it is my turbo return line. both sides are dry. line is worn..
- any tricks to get a broken dip stick off? can bearly fit my arm in there enough to pull up on it..
- FS: OEM Audi RS4 Grille, $1 OBO
- what are a set of stock 16" swing wheels worth?
- Coolant leak.. dripping from bottom of alternator :(
- Are the halogen and xenon headlights the same? Are there any diffenreces in the actual housing?
- Where is my crank sensor?
- LED tail lights...
- tech article movie link not working
- removing inside passenger door panel?
- A comment to "IamAlmostAwesome"....
- S4 OEM Flywheel on 1.8T B5
- noob Q's on performing brake pad replacements on 01 a4 quattro
- Gas Cap
- Dave @ ETA: Great guy and shop! Will do business again!!!! A+++++++++++
- hey guys, just need some info on the lower part of the front bumber.
- LWFW and Southbend Clutch's help.
- Valeo Headlight Issue (Xenon vs. Non-Xenon)
- FARK!! Leaving for H20 tomorrow and my car is throwing a fit every time I get gas! Sh!T!
- About to start my rear wheel bearing (no hubshark) any tips?
- Odd rattling sound from 2001 1.8T A4 Auto
- **Milltek Exhaust** Special Purchase 98-01 A4 2.8 Quatro
- B5 A4 reliability
- 96Q AT 2.8 anyone have a power steering diagram??
- got car started with a battery buddy.. ROUGH idle..
- Kind of Ironic: Just picked up a new case. One of the parties is Garrett Turbo Systems
- Help, I can't disarm my car alarm!
- yay for dead batteries
- starts knocking on wood*... please let it be true.. please let it be true
- creaking sound when i turn the wheel
- Is it worth bothering with a CRC spray/cleaner to clean a MAF?
- how to replace a front right axle? is it as easy as loosen the outer joint from the hub and pull it
- search - how come when i turn the air on there is a flapping noise in the middle vents...
- Sorry for the bandwitdh, I am desperate. Need help ASAP - replacing oil pressure switch tonight
- Cat Conv Question
- Apikol Rear Diff Mount [w/ updated pics]...
- ABS issues.....so my ABS light came on today....
- I will be driving it....
- How big a job to change the rear hub to lower arm bushes?... no manual.
- whats the deal with the dipstick tube breaking all the time?
- So, I will probably jinx myself here, but: the new O2 sensor seems to have cured my rich running!
- Anyone tried fitting TT V6 brakes?
- Moved to germany and don't know any good audi shops. Anyone here know of any? My b5 is acting up...
- rough start & idle
- what is the trick to disconnecting the airbag electrical connection under the front seat?
- Any drawbacks to H&R Ultra Coilovers?
- Clutch time coming up
- Update on my turbo situation: Rebuilding my turbo...questions inside/rant
- Only a few days left to take advantage of the H2O International sale at Achtuning.com!
- LOL!! Mandeep..
- service question
- Doing cam chain tensioner tommorrow, any suggestions on how to make the install go easier..
- How much do you guys spend a year on maintenance? Not mods. Do you do your own work?
- In need of some clarification...please. HP designations.
- Any gear oil or additives recommended to "quiet" a noisy manual transmission?
- gas cap part number for 2001; is 1J0-201-550-AN-01C right?
- What's everyone using for brake pads nowadays?
- H20: Head count and definitves should we swap cell #'s via a mass email...
- What are the lug nut torque specifications on a 2000 A4 2.8 Quattro?
- 2 rear q ABS sensors for $180!!.... breakers yard... now to see if they work!
- Dirty Dirty MAF sensor - anybody here ever try cleaning one?
- Where can I find a wiring schematic for these parts 4D0 941 563 A, and 4D0 941 535. TIA
- Does anyone between Maine and Ocean City Maryland need an whole AWM block or seats? FREE delivery!
- Where to find cloth sport seats?
- Why is this link not working?
- Can upper control arms (both front and rear) be replaced w/o taking out the mounting plate (ie, ...
- Well.. car is running richie rich, high rpm mid level boost - light smoke during shifts -
- So I think i'll do the Seafoam treatment...but I am still worried about it. Should I be worried?
- Has anyone ever gotten shown-up by a Corolla?
- Chrome wheels?
- Thoughts on the new sig
- We are proud to announce the release of the new Apikol Rear Differential Mount...
- Anyone know where to pic up some mesh for MAF - i need to straigten the flow that is coming
- So, put my new O2 sensor in today...... wow, coolness, sweet..........
- Do you guys know if the 17" OEM rims of B7 fit the B5 S4?
- Transplanting Bose components into non Bose?...
- What I've been up 2... Engine Pron....
- Alot of you have got mail!
- my old A4 got rear-ended, needs a new rear bumper... is it cheaper to source parts
- MAF replaced, still some stutter
- Chip BT: Who makes chips without a piggyback board for the nDBW AEB?
- Anyone know a good place to get piston rings?
- Pulled airbag....
- Our B5's > the B7 I saw yesterday>
- Paging Carson... looking for a price on that Cam Chain Tensioner for
- Kinetic motorsport high flow stock location manifold. hit or skip?
- ridiculously dumb question about dead batteries
- What I've been driving lately... (BTW crazy indian guy in this thread)
- Joey: How'd it go?
- What's the latest poop on asp stg3? STFa...
- Rattle from front when turning and accelerating - Any Ideas?
- How do I stop the power surge when the electric fan turns on?
- Oxygen and Coolant Temp Sensors - Related?
- the TIRE RACK - Anybody buy from them? Wondering about cost after shipping etc.
- Simple Post: Changing the oil
- anybody buy those tire warantte - is it worth to get it
- should i get an aligment before putting on new wheels or after
- eBay Badgeless Grill -- Anyone have one?
- Anyone know what is the part number for bearing retainer - for the 1.8t tranny
- Hoon of the day: Jeep Fought The Rock And The Rock...Yeah (and someone there had an Audi cap on...)
- How to seal a broken sunroof?
- Part Number Request
- XPOST from 1.8T Forum - Need help with boost issue on 01.5 AWM motor
- seaformed
- Does anybody know the dealer shop rate to replace a timing belt?
- Eat your heart out kids
- The Exhaust
- What all cars VW/Audi use the AEB?
- K&N Cold Air Intake Kit on 99 A4 2.8L Quattro
- Cooling problems
- Cam chain tensioner - is it different on 2001 AWM than 2000 ATW? different
- I have a confession to make...
- Paging: Bitjocky... this is the blueprint.. can i get your OK for fabrication?
- new clutch
- Anyone running a SouthBend OFE Stage 3 clutch?
- Red debadged A4 on Coastal Highway 17 (GA)... you here?
- Price check aka Riverside audi
- Prestone 5/150 Extended Life, Any suggestions?
- Suspension?
- Anyone have a 2 channel amplifier they can send me for the cost of shipping? :P
- Front bumper gap! Where do I get the bumper/well liner screws?
- JoeyCam: building the cylinder head tonight.
- ahahha OH OH ahahahah.. BAHAHAH.. oh AHAHAH..
- 1.8T Sparkplugs: BKR6E Right?
- go ahead...call me a ricer
- Flashing CEL during lunch hour . . . no scan tool.
- Just bought these torctite exhaust clamps to replace ****ty apr clamps. $25 shipped
- Strange request. A picture of a Stg3/+. Just of turbo and Exh. man from above. I'll search but....
- Picked up my Imola Avant and drove it 12 hrs home
- Radio Antenna
- For those in PA, what type of Emissions testing do they do on your B5?
- RallyVT... how did the clutch go...
- Gas/Smoke emission inside the car
- My compressor runs OK but the air inside is not cold
- Suspension and turning question for the those who love the twisties
- should i replace this part or screw it
- where to get heat wrap for stock oil feed line?
- fvcK!>.. APR R1 = fvcked... it won't seal anymore
- A First Post: Alignment question
- Vag-Com
- Timing belt went....anything else I should replace while I'm in there
- speaking of detail... for those that saw my "my car is missing" post on Friday...
- Detail day one, down.
- @ what p.s.i does the DV open up on a stg 3+ kit?
- Fuel filter clamp bit
- Rear Sway Bar - 1.8 T - B5 - Quattro
- Help! How the heck do you get the axle bolt off?
- I am so proud of myself *little rant*
- Anyone have a spare AEB MAF near PA they can ship me tomorrow?
- any advice on how to get this pin back in?
- Quick question sorry it isn't really audi related but is bank 1 sensor 2 always passenger side after
- squeeky steering wheel round #2
- Radiator Change 96 A4 2.8L
- Rear hub bush (to lower arm). PN? looking for Polyurithane replacements, can't find them anywhere
- 1999 Audi A4 1.8TQS (48,000 miles): what type of maintenance will I likely need in coming years?
- will struts off a 01 1.8T avant fit on my 98 1.8t sedan?
- Post clay bar - Pre wax pics.. not bad
- Andy: Did the wastegate fix the problem, or cleaning the maf???
- changed all my lifters and cam tensioner
- 2001 MAF and air filter
- constant clunk while driving in gear, right front axle maybe?
- car troubles lol please help
- control arm kit, good deal but too good to be true? opinions
- Hell yeah, Just won $2000 on an instant ticket. What should I do to my car next?
- mmm bbs rc 18x8.5 20.3lbs
- As of 10:05 PM 9-22-2007 I have put 400.1 miles............
- ABS Module #0 295 109 001 (the kind under the back seat) for 1997 A4 2.8 AFC
- 4ringsV2.0 ... what's happening with your car? i haven't seen an update from you in forever
- painting rear badges
- BT: new turbo question for you (us) B5'ers
- wiper arms
- Midas monkey business (look what they did to my poor exhaust)
- Yawn... just some pics.. proving the always true point.. B5>*
- *** H20 Attendees ** check in here with recent pic of yourself and the car you will be in.
- Has Beeej::nt been around at all?
- is it the Camshaft OR crankshaft position sensor?
- Can someone tell me how to test my crank sensor and camshaft actuator???
- xenon headlight turning red
- Alarm System
- I am confused. Will these really work?
- goes outside.. starts wash/wax process on the a4*
- WWAWD?
- Stuck oil pan, how to dislodge it?
- lets say a "friend" just got politely asked by his landlord to sell the spare
- Just picked up a 99 a4 1.8t quattro and apparently the dude i got it from put a BOV on it...........
- Hey JOEL!
- Need to eliminate my top speed governer, "2.8t" pulls hard then hits the governer at 130 mph
- Radio Works But Not LEDs
- hey guys, just picked up a 2000 1.8t 5sp today...
- Another night at Raceway Park, another disappointment. 14.48@95.47, 68F. I need practice
- Clean throttle body
- Fixer upper '01 1.8t.
- how does one know their cam chain tensioner is failing?
- Would it be worth it to touch up my bumper?
- Cracked ABS Tone Ring
- So let's say "a friend* had a '99 Avant with APR Stg 3 and wanted to squeeeeeze a little more hp
- Can car run w/o PS pump?
- Good online place to order a 3 foot length of 2 3/4 inch exhaust pipe?
- New insight from my friend who just rode in my car...He says it seems like the fuel is being cut.
- noob question: tires size for snows on 16" sport package rims: 205/55?
- Stock clutch break-in...500miles?
- Crap, one of my rear calipers is sticking
- Ever since switching to 630cc injectors - I've been having hard cold starts
- WTF!!!!!!!!!!! Still not it. Slowly boosts up to about 5 psi, but then stutters & bogs....
- What can be the cause of this?? Car misfiring during WOT, loss of power through the Higher RPM,
- Free shipping on Recaro seats -Today only!!!
- !!! Anyone in the Bay area parting out?
- Dude, where's my car? I have no idea...
- PSA: M1 0w40 $4.79/qt at Farm and Fleet. (If you live in the Midwest)
- Who is detailing their car like this this weekend?
- Ok...i know im a dum n00b and all..bu ti couldnt find this....
- What's the cleanest way to remove my M3 lip spoiler? Is Goo Gone, Goof Off
- Any tips for changing the lock on the trunk? and removing the trunk?
- Hope not to jinx it, but I think we have a winner...
- CEL light -- help with VAG message please
- Well.. Looks like I will attempt to do the clutch this weekend.. Pull the engine or jack stands?
- What do you guys think?
- Could someone please give me a brief run-down on the process of charging the A/C?
- Oil Season
- Had a spirited highway run yesterday on the way home.. Vid clip of a possible coolant boil..
- T28 No/low boost update: Tried some of your ideas from last night...
- Air conditioner suddenly not working
- I will have a long drive back Sunday, new ride.
- So, um.. careful when receiving shipments from our fellow AW members....
- First crappy arse video..........
- Where's Kris been? I haven't seen him on here much lately.
- let me get this straight
