- PureMS sent me the wrong CV axle, and I need a new one post haste - recommendations?
- Anyone in Pitts. PA area interested in getting a pro to show us how 2 tune susp. Maybe a day @ Beav
- any one have a rear bumper cover they are willing to let go?
- A couple fluids questions
- X-Post (B7): I'm sick of 2nd grinding in the cold: Lets settle this for once and for all!
- Anyone have fluid capacity chart, link in FAQ is dead.
- 1999 A4 instrument cluster replacement
- check out the audi trike chopper...
- *sigh* 5 yrs and search still sucks. MAF wiring question-->
- Did a restore on OEM Concert radio yesterday, what an ordeal...long
- those with defective vvme ballast and the "sand" noise inside take a look
- The JHM solid linkage and stabilizer bushing are in. Really took the slop out of the shifter
- NAMOTORSPORTS | Thule Roof Racks and Accessories Now Available!
- What would you do?
- since there are more techs on this board, anyone have access to the Mitchell Mechanical Labor
- Best/easiest way to pull oil pan/pump? Any tips or suggestions?
- If anyone has done the interior painting for the manual transmission...
- Hey guys i got a miss fire on cylinder #4.... it only happened for a minute and now drives fine
- Anybody knows what's the purpose of this green cap?...
- Is this an OK scenario>
- anyone got a part car or parting their car out?
- Noise Diagnostic Help
- Need help on picking the right lowering springs
- Stupid question...
- Car is suddenly roaring like a tractor + turbo screaming. 97 1.8t AvantQ E-spec.
- Pic of new ride
- Timing belt install...
- Whining/Sputter Noise
- Going to visit my wife's family for 2 weeks and have to leave my B5's behind :-(
- Putting in Stasis Tracksports, CPP front + rear upper CAs, CPP TREs, looking for alignment specs.
- If you had to choose between these two 5W-40 Sythetic oils....which one would you pick?
- squealing/screeching when turning heat on - ideas?
- Nice weekend
- No heat this morning - heater core?
- I think I hit a new record.
- Is over-filling the Power Steering Fluid Reservoir bad to do?
- Question regarding RS4 "through-hole" design trans. mounts.
- Is something leaking here?
- New 02 Sensor FTW
- Looking to be a new audi owner.
- does carbon fiber tend to smoke when heated up? more so the resin i guess and @ what temp?
- Problems, Problems, Problems.
- Brake Upgrade BT: Looking for a good setup for getting into track events...
- Carson, how much would this part cost me from you? (haha)
- Will this work in our cars?
- is this a good product?
- cd and cd changer buttons not working....
- Sorry to say guys, but I think this is the direction I'm going to go in the next couple of years...
- ATE or Ziimermann front rotors? same price on PureMS...
- Streakin thanks for coming over and swilling some beers back with me during the test fit:)
- outter CV Boot clamp?
- Probably been covered, but silly question that got me out of bed (apr stg3)-->
- transmission wont engage, seems to be stuck in N
- brake rotor size
- 1997 A4 Sedan 2.8L Can't Remove Front Bumper. I Have Removed Two Screws on Bottom
- One of those days ,find rear diff leaking again and then the VAG-COM laptop hard-drive fails
- Anybody bought from these guys yet?
- Today I got parts to fix my Avant
- What valve is this?
- Doing Whiteline rear sway found out a tool tip for doing rear links ..16mm bike cone wrench
- oil temp gauge
- new adjustable fpr for stock fuel rail....
- Thoughts on this wheel?
- Stuck rear ABS sensor! Any advice from those who experienced this?
- Cleaning Sludge and Carbon Deposits flooding engine wz Diesel
- where do i apply the sealant when when changing the valve cover gasket?
- So I took my car to the shop today, no codes but the engine is still stuttering... Help?
- anyone running a magnetic oil drain plug? where do i get one?
- How to fix vibrating headlight inner housing?
- if anyone attending the 2008 Northeast Spring Bash has an MTM tuned vehicle, please e-mail me
- Imwhatever (a mountainside?) and whoever else... The 75Ohm resistors are in!
- Electric Cooling Fan Questions...
- Need help with torque spec for head bolts...........
- ET +42 wheels (18x7.5) fit without spacers?
- Silver Streakin /and other track junkies: Any problems with high oil temps?
- that dude in the kn truck commercial changes his oil every 2500 miles
- Headlight question
- BPV REPLACEMENT
- Weekend plans? Whats yours?
- Test pipe cels today after 5 months installed. Question inside.
- is this oil sludge?
- Grrr, now I know why you should pull the intake manifold when replacing the PCV...
- Not only was my two-year old power steering pump shot....so was my accessory belt tensioner/roller.
- Poor Poor Audi !!1
- Fawk Me! (Messed up Valence)
- Any recommended maintenence/repair shops in San Jose/SF area? Need some small work done
- anyone need an intercooler shroud?
- ANNOUNCEMENT: Pricing Change for AW Orders, effective 3/17/08
- New rear brake pads are rattling? Any ideas
- Follow up, I've been running at 5lbs last week. pulled/cleared codes I've searched but have some q's
- Picked up a new ride.....
- hey kris not a for sale post... i'll give it away... silver hood..
- Any recommendations on where I can purchase a set of new 16 inch rims, beside TireRack.com
- he he he he he he .. thanks brian!
- Any real reason why I shouldn't chip my 2.8?
- Question for track junkies rockin' Boxster calipers up front....
- What would cause a slight fluctuation in idle speed on a 1.8t?
- Wierd White Smoke, New Cylinder Head. Need an AUDI Dr. House
- I saw there was a group buy on Zender B5 avant roof spoilers a while back
- HID head light bulb, original? after market?
- What would you make of this? Engine falters.
- Temp Gauge
- Anyone ever have an O2 sensor start working again?
- Exhaust pipe and Aluminum pipe
- I've got some 12v stuff in the classified, but...
- Will a 16x8 set of wheels fit on an a4 2001 from an A6?
- Who was trying to swap their CF hood for a good 'ole steel one? In Cinci IIRC.
- 16" stock wheel price?
- check engine light
- Avant guys: roof rails getting pale and dull. Repaint or scuff and buff to aluminum shine?
- Damn you B5 A4....why do I hate and love you so much!!!!!!!
- Does anyone know if there is a good Santorin paint match from a automotive store?
- Anyone looking for a deal on wheels...
- LIght Weight Braille Battery Kit!!
- Just picked up a B5. Need your guys' help!
- Looking for a dirt cheap pair of rear brake caliper carriers - anybody?
- Coilover tools?
- Why do I do things at night in the dark?
- ID this turbo plz:
- How do you guys remove the cam plugs on the back of the cam banks?
- Koni adjustables - where is the adjustment point? I have the Koni/Vog
- Sigh.......looks like my power steering pump is going out on me.
- Paging Carson@Riveside Audi or any other parts gurus...
- Valve Lifter Replacement
- AW Poll: Run OEM RS4 bumper, or buy OEM S4 new and spend the money on a repaint?
- Leaking oil... rear main seal info needed.
- AEB 1.8T Front O2 Sensor (Link included)
- I am working on my old B5.
- Oil sensor leaking. Looking for a part number.
- tired of paying $94 to slot my ECS 312x26 two piece rotors. Looking for alternative suplier
- *sigh* finally, something besides the engine having issues...lol--->
- Will these hid ballasts show the headlight warning symbol on the dash or not?
- Need help - cleaning wheels
- Need K03 turbo for 2001 A4 1.8t in good working order........
- Headliner Replacement?
- I see a familiar looking car on the Joey Cam!
- Trying to determine noises
- Replacing torn outer CV boot; same as on Vdub?
- Tip to remove starter on 1996 12V V6 A4.
- 1) April 11-13 2) April 18-20 Which weekend works for those who be joining me?.....
- If i have to replace one coilpack, should i just say screw it and buy 3 other new ones?
- Mica, Joey, box enroute to Joey. I think it's what you need. If not, pls let me know.
- how to install FK Angel eyes headlights on a 2001 B5
- How many here have Hibiscus w/ Terra Cotta? Rare combo?
- US/DOT S4 HID cutoff
- Drove the 500 hp STI today..wow,whatta rush...<long>
- Who wants a brand new set of WearEver Silver front brake pads w/ wear sensors?
- Shipping a car from CA to NC, anyone have a company they can recommend?
- What color is this?
- Looking for Crimson K6 18x8
- Boost Loss... :(
- It fits!
- wow... wow.. not even sure what to say... found this gem WW (only text)
- Has anybody played with this thing, yet?
- Mica
- Just want to make sure this is the correct part before I order it.
- Does 10" hg vacuum at idle seem odd?
- $440 to install rear wheel bearing - labor only - fair price?
- Picked up a a few new things yesterday.
- Guys, need your opinion on whether this car is a good deal/buy or not ...
- (not my ad. don't know the seller.) GT2871R, ATP mani, etc. for sale here in Philly
- 2008 NORTHEAST AUDI SPRING BASH-updated website online now!!!!
- Paging Carson: how much for a pair of 2001 rear bulbholders? 8D9 945 257 I think.
- My clutch finally failed in upstate New York.. near Schenectady on I-90. Time to replace.
- Paging MonkeyLover: Bring me your car.
- any tricks to eliminate the excruciatingg sound of lowering the windows?
- Does anyone have a stock spare B5 15" wheel that they want to get rid off?
- Alternator question....
- P/N verification; Not sold separately?
- Anyone remove the roof joint molding/seal?
- paging ExtremeAudi...you inspired me... I ordered an 80gb Zune ...<edit>
- You've all be mildly well behaved....
- Front wheel bearing part number, need the VW one.
- How bad is this?....(everyone's gotta look with a sub. line like that)
- Looking for 2001 A4 RH (passenger) side tail light for sedan......
- So dudes, before I purchase the H-Sports sway bar set I assume I should upgrade my
- Finally trying to rid myself of CF hood, should I propose straight up swap or ask for money?
- How to identify these springs?
- Have you all been good boys and girls today?
- Clutch Issue! Need Help ASAP
- Thinking about putting my coilovers on tonight
- Help! Strange coolant leak!
- Cleared up a couple things with GIAC about Hammer File.
- paging Dung Beetle Hackjob Roving Rover...
- Anybody need a spare ashtray?
- Need advice (or my head examined)
- I need a set of sport springs.. anyone got some laying around?
- Is this the preferred spot to tap for a boost gauge?
- How do i adjust my ebrake to actually hold?
- Wow....B5S4 Avant at sedan pricing...for those seeking to jump off of the ship...
- Does anyone have a front plate mount they can part with for my wifes B5?
- A few questions regarding SIII+ and Water Injection
- exhaust
- Confused about which O2 Sensor to Buy (link inlcuded)
- how feasible is an engine swap from a b5.5 passat TDI into b5 a4 1.8tq?
- car drives like new again after got some work done, price sounds right?
- Mirrors
- Slight loss of boost
- small windshield crack from rock... maybe more of an insuracne question, but...
- Fuel injector failure?
- DV making noise
- so tempting
- Where can I get new BBS LM reps from?
- With all this BAT talk lately, i have a question. What are realistic numbers to expect(more)
- What is this pipe?
- Cool keychain for BAT owners
- <Rant> the AW classifieds section sucks and the AZ classifieds is filled with 19" and 20"
- kind of off topic
- Inspired by an earlier post, my 97 1.8tQA is coming up on 100k miles..
- hey hey hey, So i got a test pipe. Put in non foulers and there still is a check engine light.
- bought an A41.8TQA and have serious issues
- The story of how I lost my anal virginity. (B5 related)
- squeak/grinding when turning - tie rod end?
- all this talk of BT cars, I hope to see more of you at the events like Redline TAs (my A4 on SPEED!)
- Audi OEM parts 4 sale.......
- hmm, noticed some overspray on the inside of the passanger door
- wheel spacer question
- someone local is selling some audi parts for a 99+
- Front Doors Won't Open
- finished up putting a factory new longblock in my 98 1.8t last night..
- ala rallyvt post about running BT, post up your not running setups
- So dudes...now that my Audi has 100k miles on it... perhaps it's time to install
- CEL-P0411 Sec Air Inf Flow...and I checked the SAI pump and found water!
- Warped Dashboard Repair - What type of adhesive?
- AEB - Front O2 sensor is the only one that matters correct?
- Zeitronics installation question
- Oil Temperature, what should it be?
- got the car all cleaned up, claybar, polish, wax paint. Cleaned the int to near showroom ready
- cabin blower motor
- Diesel in the crankcase?
- Best place to get O2 Sensors from?
- Off Topic, but... I turst you dudes the most (wheel problem, volvo)
- rattling sound as I pass 3000 RPMs - any ideas what/where to check?
- Does anyone know where to get the headlight washer cover? The one that sits on the bumper.
- Poll - plain and simple - B5 A4 BT (Big Turbo) roll call - 4cyl - unlimited displacement
- Locating oil leak... Help (30v, 99, q)
- Brake Job gone bad... need tips/help
- A question on Secondary Pump?
- optima red top battery users what one are you using want to make sure i order right one
- I'm looking at a AWM engine (in a B5.5 passat) which makes a
- bout time for an update...
- Since it's a slow day... how she's sitting
- Global Motorsports Group proudly releases its 1.8t Big Turbo Kit.
- $8 to ship a $10 hose. Argh.
- there is an easier way to wash you engine guys!
- Here is my dilema:
- is a B5 with a k04 (pc16) worth any more in the private market than it would be if stock?
- Sebring 2008 Club Shirts Now Available for Pre-Order
- I need a little help on this one.....
- Vag-Com airbag code help needed
