- hey BSK, what's a nipper clipper?
- Throttle response problem
- Probably a repost, but . . . . The B5FAQ link picture?
- how does the bad n75 sound like?
- P0441 code help
- Hey Shinobi.... I'm going to be down your way next fri-sat-sun if you want to Vag anything else...
- recalls- ignition switch, lower control arms
- Clutch service interval and some warranty issues...
- UUC short shifter question
- ECT sensor prob. 2001.5 AWM 1.8t
- Would you rather have the 1.8T, or the 2.8 '98 and higher
- Just bought a 98 a4 quattro, need help with rims
- Lower Control Arms Replacement
- APR question
- Question: on a sedan, under the trunk there is a round plate right under
- Problem with unusual tire wear, need help!!
- HELP!! Can I use the GIAC Transmission Chip together with APR programmed ECU in my A4??
- n75 valve?
- Need help with a leak
- back from the body shop... with a new fender
- Having a rear differential leak. looking for DIY Link and Parts N
- Resprayed console in primer again tonight. Looked good.
- check engin light
- noise in first gear
- 1st post....just picked up an A4, have question on coilovers
- I just tried to swap the Bosch 317cc TT injectors in for the stock ones & they don't fit. Help.
- Fark! Installed my ECS stg1 brake kit and my wheel weights contact the caliper! Is is possible to...
- So I took my car to the mechanic to get my brakes checked...
- Going into limp mode. 2000 A4 1.8t W/AWE turbo kit and their dv valve. I'm not alone on this.
- 17" Flik Lex for winter wheels.
- What are the typicall manufacturing costs for german auto makers?
- anyone else noticed this new turbo/software setup?
- How hard to replace the a/c compressor?
- Paging Poolemac:
- question about recalls
- Passenger brake light bulb missing. I think it was like this from the factory
- has anyone ever put hids in a non hid valeo light
- Help with PN please. Cant find it in the ETKA
- HELP Electric Problems
- WTF Audi of Wilmington? Re: oil drain plug crush washers.
- Shinobi has a VERY odd problem with his car... he needs help guys!!
- HELP! Can someone please identify this brake rotor for me....
- Do they make a chip for a 2.8 12v???
- So I threw codes 16684, 16686, 16687
- anybody want some hid headlights from an S4.... has broken mounts though
- so the umbrella in the door is getting around the cars.. when will audi get em?
- Dr Jekylls S4 recovered car pics. his car was stolen from the staybrigde hotel during WF
- Talked to Desion again and they are only doing an adapter for rca inputs.
- Need new 12v exhaust/Who makes them..
- Anyone here ever changed out an AC compressor clutch?
- Alright, I searched...
- fixed the vibration problem (sort of)
- Problem : Head unit powers but nothing to speakers.
- Bentley rear brake info needed
- weekend poll: whats going to happen mod wise with everyone this weekend?
- 96 A4 Quattro warning lights
- That faint noise I have been hearing is the wheel bearing IMO, but can't get car in till 16th.
- no new post in 2 hours, everyone off today? BSK go ahead and post your who's doing what this weekend
- replacing ignition switch
- pinstripes are for anti-semites and fascists.
- Answer to Ray Khan about the Sea Foam:
- Well after 900 or so miles 300 highway 600 town, my new clutch just won't grip..
- Answer to TighTT about the mani.
- New car time?
- I dont trust mechanics....
- looking for sub/amp installation faq/howto
- New exhaust??
- RallyVermont: where in VT are you? (I assume you ARE in VT!?)
- im thinking about TT calipers A8 rotors(search didnt find anything i liked)
- Had an unexpected run-in with a Tiburon last night...
- rotors warped?
- oz sl 17x8 found on ebay in Anthracite
- Need a trunk latch
- Frustrating blower problem... appreciate any advice.
- totaled....a couple pictures
- IF you had a choice of RED BLACK OR SILVER porsche calipers which would you chouse and why???
- meyle control arms and tie tod end and hr springs and blistiens shock sport install....
- what chip is the best to get for me? i want to go fast!!
- Illumination problems on dashboard panel
- One Month until Suspension.
- Wheel Bearings and CV joints are considered normal wear items under the Certified Warranty correct?
- 2.8T ? possible?
- Any good shop in NY???
- Motorola hf850 Bluetooth Car Kit Wiring
- Where is the low pressure switch for the A/C system and which pins do you jump on the high pressure
- 30v chips
- my brakes on the right side, not sure which ones are squeaking real loud. Pads look fine though
- Please Help...my dying '97 A4 1.8tq
- looking for PROJEKTZWO wheel (s)
- HOW DO U CHANGE THE CORNER ON!
- winter wheel setup
- AutoMeter boost gauge install pictures...
- Shinobi...
- sluggish and rough when driven continuously
- People with upgraded ecodes..
- Pics with Wheel spacers?
- no avant today.... which means tomorrow I get it back
- Need help with three fault codes, p1113 and p0441 and p1136. Please help me...
- whats going on with people getting hit in their cars lately?
- Ecode wiring harness?
- Slow Speed ABS Problem??
- So the flex pipe busted on the downpipe need some help...
- Paging leosphere: Did you ship that manifold??
- has anyone test drove the b7 yet????
- Center console trim around tip plate??
- ot: is my website getting giving you a dns error?
- Yum! New toys!!!
- J271 Main relay info
- Anyone with a tip chip that can help me out?
- High performance headlight
- Just got my Hyperboost HX Compact!!!
- anyone try Revo tuning w/the GT2X/GTRS Eliminator Series? they do tuning...
- Auto trans - APR or PureMS snub
- After speaking with Brian about what everyone on here told me about ...(kind of long)
- Anyone know if TT front seats can be mounted in an A4 w/o major fabrication?
- is it just me or does the search option seem to really sux recently?
- Take THAT extended warranty...
- Reoccurring EPC light
- Has anyone had their quattro towed from a parking lot...not on a flatbed?
- PES T28 kit uses 440cc injectors...correct? like these---->
- Anyone use the ATP fuel rail? Anyone know anything about it?
- If the wrong ps fluid was put in my car could that cause the seals in my steering rack to let go?
- suspension on 18 inch wheels
- Where is the A/C system low pressure switch and how to jump the high pressure switch?
- Totaled
- Need help.......Coolant flush procedures on '01 2.8 30V. *BWW*
- Magnaflow exhaust
- Do you guys know how to replace mirrors switch?
- driving with shot control arms and links
- mmart, I dropped a can of seafoam in the tank over the weekend, car is running better now
- Colorado audi club
- Where is the Cam Tensioner gasket on a 1.8T Quattro
- Please Help- Need some advice about a sound.
- Engine cut out
- Bored at work - Big Turbo guys post. lets see who reigns over all..
- Leg Cooker
- Update "Car won't start w/63000 and timing belt hasn't been changed......
- has anyone ever replaced their factory alarm "siren" with an aftermarket siren?
- Confused about spark plugs with k04
- Main relay fault
- Please Help - Cannot find source of Noise
- car troubles... some advice would be appreciated...
- Advice for TB changing on 1.8T ATW
- How did Hyundai beat Audi?
- Control Arm Replacement... what joy
- Is it just me or are the grey cloth sport seats the hardest thing ever to get clean?
- Paging: Anyone in Poland or Germany...Need parts
- widest tire stock 15" b5(99) A4 wheel
- Oil Smell???
- Going to tint windows. I want to get a medical waiver for darker tint...
- im thinking about adding naawwwzz and a parkbench spoiler to my car
- Everything regarding remote range problems on here is pre-99.5. I have a 99.5 and my remote range
- Lighter Battery fo 01 1.8t?
- NOS on a 2.8L?
- Baffling and downright dangerous issue, requesting assistance
- Just arrived 18" B6 S4 wheels!
- Removing Battery from 2001 A4 1.8t
- More A/C questions, Please Help
- www.hidvisualcreations.com
- Need to find a place to buy a good stage II clutch online...
- Just arrived: Koni Shocks/Vogtland from PureMs
- Were can i order a repair manual for my car with over night shipping?
- does anyone know how i replace my corner signal lights
- So who here has plates from another state other than that of which you reside?
- which shocks to invest in after mine are going down the drain at 130k...
- High boost Diode mod...
- who has the video of the 9 second 1/4 mile rs4 (iirc its from poland)
- Has anyone purchased a GT307 from ATP?
- Dung Beetle
- Stock ecu and high boost ?
- Cam Tensioner Gasket Leaking Oil
- need help using VAG to diagnose turbo problem...
- anyone know a parts supplier that stocks rear control arms?
- Custom Cone intake installed today...pic inside.
- I found out yesterday that I NEED a VAG to check my transmission fluid level.
- my city light comparison
- help! speedometer problem
- boost leak at t28 housing, can this be fixed
- Haven't Posted In Awhile... Thought I'd Show Some Pics Of Where I am (BWW)
- some pics from the maine coast (16 pix BWW)
- Silver B5er's Post your pics
- Need help with AC
- What do you guys think of this for my bro ... he wants an A4 bad after he's seen/drivin mine
- Hyperboost DV *check*...Second best mod behind Short shifter!
- Valeo Wipers Installed (Aero style...)
- Whats everyone running for plugs with a k04??
- Boost Part Question
- TBA with VAG1551, still not running, Help!
- Extended Warranty
- Part number for bolts that hold turbo oil line heat shield in place?
- aeb question, whats the line which bolts in between the runners and goes back through the firewall?
- Turbo Hoses
- Looking for Driver Side Fender in volcano black is possible
- advice needed: tracking down noise from engine compartment
- Question: Will 18 by 8 wheels with a 30 mm offset fit my 98 A4 1.8TQ
- Brian at brian's garage told me there is no f'in need to ...
- anybody have a right side 2 piece headlamp they want to donate to my avant
- anybody got a silver S4 bumper they wanna get rid of?
- Can anyone tell me if this is a DBW or NDBW ECU? 8D0-907-557-P Thanks!
- Bad Chip?
- 1st impression: ATP GTRS Eliminator Series (long)
- lol, local audi owner selling a b5 s4 avant, 6spd,
- Just got speaker adapters from Nexxia...
- Anyone ever see this suspension before
- How to fix a 22.3 and/or 18.3?
- n00b question, this is my first car, id like to change the oil myself,there a writeup for the 2.8?
- Anyone know Bruno's number in NYC
- what's a good brand of spark plug wires for my A4 (30v) and what should they cost?
- Help please, I STFA but can't find a P/N for a right front impact absorber
- OK, code (singular) pulled at lunch: P0441 EVAP Emission Control System - Incorrect Flow. From STFA
- Advise needed regarding a hit and run
- My friend has a 98 a4 in black and we both need paint work. Was brillant black the only black in 98?
- anyone here have an OMP strut tower brace?
- anyone sellin used coils?
- Anyone here running 993tt calipers and rotors?
- normenwinata@yahoo.com
- f'n idiot drivers...
- '97 headunit to a '99 headunit
- book time for tie-rod replacement?
- [removing seats] - any DIY or tech guides?
- Oil Pan Crack at drain plug
- Big thanks to Jason @ ECS. Ordered my stg1 brakes last Thu & they're on my doorstep now, x-cty.
- Anyone know what used S4 sides are going for these days?
- Those asking about my new intercooler last night, here's some pics from 1.8 .8T Boricua
- *repost* help
- having some fun with the construction next door
- Engine Oil leak
- electronic mirrors don't work
- A/C compressor
- Silly question - How do you remove the key off of the switchblade remote?
- OK...I did my searching but want some up to date info...FMIC questions...
- At work, too busy to search...O2 sensor will trip the CEL (hopefully that's what....
- Anyone thinking of selling B5 A4 1.8TQM....
- X-Post: DIY brake upgrade question.
- will these fit a 99.5 A4? just wondering, because i dont know..
- Is there a trick to refitting the front bumper on a B5 A4?
- I'm pi$$ed! I woke up today to find two huge dents on my hood and two smaller ones on the roof of
- Anyone near Rahway?
- Reiger RS4 Bumper For Sale
- block ;)
- Shock absorber is leaking?
- Vibrating at High Speeds
- Bad day at the oil change place
- Ecu Fuse?
- will someone on here please part out their car and sell me the AWE vent boost gauge real cheap?
- DIY clear corner mod, *check*
- Looking for an A4 in Colorado
- Selling Avant Garde S wheels...
- which OMP strut bar for MY2000?
- center display problems...
