- Start problem after clutch change.
- Will 99 A4 1.8T Sedan Sport Springs work on my 98 A4 2.8 Avant?
- AC not working above 100 degrees (loc: phoenix, AZ) please help...
- 1999 Audi A4 1.8TQ manual: car suddenly started shaking and check engine light started blinking
- Kind of urgent, two part post...Audi A4 and VW GLI both acting up...
- Wiper transmission part # not showing up..
- will these rims fit?
- stock brakes suck. that is all.
- Um, couple of questions
- Paging ModifiedA4
- Free rear differential for a manual b5.
- Secondary Air Injection (AIR) Pump - air blowing upward!
- Anybody have a detailed/close up picture of how you attached your FMIC on the hot side.
- is this recall still in affect
- Yanked my intake manifold out and throttle body for some R&R work today
- For those who are doing or thinking of doing a BT or BAT this looks like good reading.
- FREE FREE FREE!!! THIS WEEKEND ONLY NORTHEASTERN OHIO BRUNSWICK AREA..
- Isnt there a way to install games like tetris for the center display using vag-com?
- So I found some old, pretty random pictures I've saved through out the years from this forum
- Why does it seem like I am the only one with this part?
- Been a tough year, and now this
- Still trying to overcome Too Rich CEL
- Poor handling - roll bar mounting bushes?
- Any one able to run a carfax report for me?
- Shocks
- Follow up to earlier 02 question, time for a cat?
- Anyone figure out something neat to do with the big red riser from the Optima 34R Red Top?
- Vag-COM
- Quick jaunt out to Seattle and back in the Avant. MPG data for '98 30V over 1K mile trip
- I am amazed at how closely the AW
- Should EVAP purge valve go click?
- Wheel offset?
- Words not needed...
- On an AWM, what is the little black box on top of the valve cover that has 1 brn wire to it?
- GT2871r Full Set Up Questions
- Is there any place I can get clutch alignment tool in person?
- How and where do I install a MBC??
- I STFA, Siphoning gas from a B5, is there a Siphon blocker or not?
- Control Arms?
- wheels are on and question about lugs
- The wait is almost over.....
- ClutchMasters Stage 6 FX600 Pictures...
- is it ok to mix Zerex G05 and G12+/G12?
- Guh..
- Question about Timing Belt...
- Finally! After over 2 years of sitting in the basement the Boxster calipers are on the car...
- Mica-not driving your car this weekend. Plan on picking it up next weekend.
- Curiosity question: How many of you out there also own/owned Vdubs?
- Changing the power steering fluid didn't get rid of this intermittent popping, groaning noise
- Brake pads for the track...need help deciding
- Sorry Doug =(
- hmm, still hunting the rattle issue. isolated to the right rear (i think).
- Anybody want to link me to a Throttle Body Boot...
- Just because I think of the worst case scenario....
- Diagnosis Question: Do I need a new axle?
- Will this fit aluminum Fidanza flywheel?
- New format or not.. I'm not going anywhere. Who's with me?
- what's the recommended orientation for 710N's for stage3 cars nowadays?
- If the world implodes with the pending changes going on, I just wan to say Thanks B5 A4 board!!!!
- Clutch and flywheel problem, urgent help please~
- Silver may be the fastest...
- my AEB 1.8T is eating coolant at an alarming rate.. any ideas?
- HELP! '96 A4 is posessed...
- who was the guy to contact to order replacement seat covers?
- So I can boost past 20psi now, but a new Clutch and used but goodTranny are well.....
- How much do you think its worth...
- Not much of a metro or anything, but when I look under my car and see the....
- Do dealer replace flywheel when they do clutch job at 60k?
- Found a nice oil filter comparision web. Would like to share with audis.
- Car keeps dying.
- Does anyone have any track pads for stock brakes? ...so that I don't have to cancel next weekend's
- Holy crap. They DID do a good job of making the new forums look like kawf!
- Should I sell my wheels with the car or seperate? Any ideas?
- My mechanic is replacing all my O2 sensors...
- Bad handling after alignment. Anyone know the alignment procedure?
- Wanted: A few cool cars! WaterFest 14 is rapidly approaching..
- So I think I finally licked my A4's problem with the Load Calculation Cross Check.....
- Dead horse subject: The R32 needs new front brake pads
- Can I resufrace dual-mass flywheel on a brake lathe...
- a little too much
- Will this fit A4 Quattro it looks the same???
- I think I've made up my mind on the flywheel. Going with Clutchmasters.
- Some potential sig material sent to me tonight...
- Lol.... my car was at a tire place for a "slow leak" fix.......and they had to wait for
- what else do i need
- Help with diagnosing brake problem
- New to Audi world
- How about some straight A/C answers... I've never heard of keeping the car off while re-charging...
- Headed for Seattle in the morning for a few days. Anyone there parting out any B5's?
- ECM schematic
- Wowzers! A D1R bulb is selling for $400 at my place of work. Cost is $194...
- Stock Symphony non-bose, Bose wiring in place?
- Automatic Transaxle 01N or 01V . . .
- Does red strut cartridge = Sport Suspension?
- Would 17" OZ UL's fit an mkV r32? Umm it's off topic I know, but the r32 forums are quite dead.
- When selling stuff online, what it your preferred method for transferring funds?
- hrmm. trying to VAG my old car (1999.5 1.8t 557P) and am having some issues...
- Need a new flywheel. Car was stolen twice now and the one on there is in too bad a shape for...
- Finally installed new tranny mounts thanks to Doug (free stock drivers side) and Avalon (034 street)
- ABS and Brake lights
- Anybody ever have any luck ordering from freakin' "Tuning Zubehor"? every time I
- Does anyone have any stock rotors and pads collecting dust? I need to remove my StopTechs for repair
- Eurocode Drops Pricing for Summer on Front Mounted Intercoolers!
- So... I got a Rieger RS4 front. Many questions... Also, call to pics.
- Paging Nick Wilson:
- Stage 1+ to 2 clutch poll: Which kit do you like?
- anybody have a stock cat they can part with?
- In general, can fex pipes be fixed?
- PSA: Audi jacked the price up on B5 RS4 grilles....
- Feedback requested: CF Hood ideas..
- *sigh* another $1.5K charged to the credit card for the the statue....
- Anybody pass smog in CA with a GTRS?
- AVO Springs????
- Three Beeps and good MPG
- Who's running a Apexi AVC-r and external gate?....
- So I bought a non-running Audi A4 2.8 12V......
- Extremely low priced wheels and wheel and tire packages at Achtuning Qty limited!
- A little more dremel work. Fits in nicely. Need to pick up some metal and rivets tomorrow.
- Problem . . help!!
- Incidently 220000miles clocked yesterday..on one timing belt
- Anybody looking for hid ecodes?
- WOW, put in a new MAF, air filter, copper plugs, and pre cat O2 sensor...
- new fenders and valeo 1 piece's. Calling any UK folks....
- DEPO lights?
- SPUTTERING,
- saw this today....wtf?!
- etiquette question
- Repost from S4 B5 Forum... you all have to see this mess
- 2001 Wheel Bearing Size(s)
- Today is a great day.
- So how does tomorrow work with the new ...smiley-format ?......
- Valve covers leaking after I changed the seals
- Does anyone know any honest mechanics in the Washington DC area?
- Can anyone confirm that the timing belt tools for the S4 (3391 & 3242) also work on the 2.8 A4?
- I have a question about the driveshaft center support bearing. Please help.
- How do I get my alternator out of my 1997 A4 quattro??????????
- trans, diff fluid change-do I have this right?
- Can anyone in Eastern PA/NJ do a clutch install this week for $500 cash?
- Metric Systems in Cambridge, MA - does not honor job quotes....
- I need a left rear ABS sensor 2001 A4 1.8t with auto adjust headlights.
- Clutchmasters FX600 twin disc enroute...
- Will I see any noticable performance gain by installing a DP with milltek exhaust as opposed
- Ug....not having internet at home sucks...=(
- O2 question - Bank 2 Sensor 2
- Hey guys, I'm back.
- Ambient Air Temp?
- Just replaced cracked outlet pipe, car now has great accel again up to 15psi, but when idling, shake
- thought i'd share...
- Random thought of the day: Was there a B6 RS4?
- What's that free audi parts website where you can sell/post audi parts?
- Does the roller that fits below the cruise control switch lay flat? Can't find a photo in the
- Installed a boost gauge last weekend...boost issues...?
- Operation iPhone dock install day 1 pictures.
- aerocatch hood pins locks or not
- Anyone can decode a radio with serial #???
- Parting out 2001 Silver A4 2.8 Manual quattro
- Soo... need an opinion>
- I just got back into the audi family thanks audi junkie
- where can i get an intake pipe painted red?
- Anyone have experiance with this guy on ebay?
- Got a set of 15" Oem wheels looking to get rid of cheap and quick anyone intrested
- Gutless 1.8T w/ AC on
- Looking for a part number...
- uneven tire wear on both rear tires. please advise.
- Can someone post a picture of a shift rod with the shift surround removed? Thanks.
- electric fan runs all the time regardless on engine temp on 2.8Q
- reporting death of an "R" revision coil-pack this weekend with ~30K miles on it..
- Is Mobil 1 10W-40 High Mileage fine to use for a 30V 2.8L engine?
- Exhaust Diameter 2.75" vs 3"
- Interior trim verification...
- Guess what? A transmission refitment question!
- funniest thing ever - i think the stock 1.8t can run with them
- Results are in...I got 2nd place in Best of Show at Audi Expo today.
- Help: Dim Xenons
- Geez, electrical gremlins have struck. Figure this out for me pls. No headlights, wipers, climate
- Off Topic Poll: How many of you guys are members of other online forums?
- 100,000 Miles
- 01 1.8t 135k
- I updated my oil dipstick LED for the hard to see 30V tube
- Tire Options. Thinking of 225/50/16 rather than 215/55/16 Kumho Ecsta ASX. Opinions?
- help - stuck on vacation weird problem
- Installed my Intrax front and rear swaybars today, one of the studs that hold the front brackets....
- How to fit the pressure plate?
- Question: Is it worth replacing an O2 if I have an exhaust leak pre-sensor? I was checking for leaks
- Paging Audi Junkie: You or someone you know didn't buy that Silver B5 Avant in Missoula did you?
- Any B5 guys going to the AudiExpo today in Burien, WA?
- Aftermarket grill. Anybody know the manufacturer or where to buy?
- Hawt Melange Pics
- Purchasing a 2000 A4Q 1.8T
- I'm thinking I got a bad part. "like new S4 exhaust"
- okay time for insurance question
- I also need to recherge the AC whic one do I use 134?
- anyone have spare front driver side window regulator for sale???
- I finaly finished the trasmission work
- while Im at it its oil change time, what filter
- what transmission fluid does everyone use and what socket do I need for the bolt
- Slave cylinder grease...
- transmission or clutch
- what's the best brake fluid i can get locally?
- Anyone recognize this '01?
- What's the "trick" to installing the release bearing?
- Quick Question?
- we dont have ignition
- Anyone want an RS4 grille?
- How much damage can a Jeep cause at 5mph?
- She's gone :,-(
- Front brakes honk after getting gas? WTF?
- Changing my brakes and notice this very uneven pad wear, anyone make any sense of it?
- Finally I broke down and replaced my radiator. The thing has been leaking...
- Paging Dung Beetle: YGM (The real kind) ... sorry it took so long (open carefully)
- Halogen E-Codes?
- Were these Achtuning wheels ever released?
- What does AW recommend for a FMIC
- Which of our approved vendors will rent and send to me a fender roller?
- Car advice..
- What's better, K&N cone or K&N direct-fit filter replacement?
- Is there a way I can not view signatures?
- can anyone verify the size of the axle collar bolt?
- 17" RS4 reps with new Kumho track tires posted in classifieds. thanks :)
- Cracked my windshield
- About to buy a '99 2.8 A4 with 140k miles. What to look for on the test drive?
- Light Not Working
- A4 2.5 TDI Quattro Windsreen wipers
- finally eliminator turbo is in!! getting the tune tomorrow, hopefully all this trouble was worth it
- when a wheel is cast/spun what does it mean in terms of rank in strength
- Looking for 4 used rims in NJ or EasternPA. 17"s or nice 16"s.
- Broken coil spring...
- thanks to Roger... just found this pic of me in my A4
- new to audis need guidance
- anyone bought the $98 belly pan from ECS? does it fit directly?
- looking for a rear bose speaker for my 98 A4 , anyone??
- H/S work wheels
- Going rate for used exhaust? Milltek parts.
- What is the going rate for a set of 99 A4 headlights that are used?
- The casavant has just been picked up from WMS and is on its way....
- Are diamonds really a girls best friend???
- Did the APR 91 chip yesterday at Carrera Motors in Bend, OR
- Does anyone have a spare shift linkage lying around?
- Recently had driver's side inside door handle unit replaced. Now side rear mirrors will not move.
- For your viewing pleasure: Panama to Alaska old timer group passed through (worksafe)
- What is recommended engine oil for 2000 A4 2.8?
- "So is your car a v8 turbo or a v6 turbo?...."
- Is there a block on VAGCOM where I can check engine oil pressure?
- These engine vacuum hoses can't be good?
- Whats the absolute best method to get every drop of oil out of my coolant system?
- picked up some A6 2.7 wheel for auto x - yummy no spacers required
- are all audi oem wheels ball seat
- replaced batteries in key.. Now it's not working
- ACHTUN!NG | 19" B7-RS4 Style Wheel & Tire Package - $1250!!!
- Does anyone have measurements for the piping for a FMIC...
