- Do all AEB motors use the same spark plugs?
- Strange LOUD rattle from engine compartment??
- New fall sig
- how do you check for misaligned drive shafts?
- where is that tool?
- This school thing is ruining my modding
- This is great...a lawyer on the B6 forum preaches that a chip
- fwd center cap question for new rim, help please!
- 30v sc on ebay
- Why are my dyno numbers low? . . .
- 12v supercharger.... on ebay??
- Audi Rentals
- ok, again, where is the ecu located in my 01 a4T quatro??
- One more race spring question...
- Do I need to replace my tires?
- How does one check the wiring harness between the ECU and TCM?
- WHERE IS THE COMPUTER LOCATED ON THE CAR?
- i searched.. but.. any good audio shop in md/va/dc?
- Anyone want to trade an APR snub mount for a stock 4 bar fuel pressure regulator?
- Just go in an accident...please help~
- Caractere Side Skirts & Rear Bumper questions
- Anyone have a sound clip of HKS BOV in re-circulation mode?
- coolant leak - 98.5 2.8 30v AHA - Need help.
- So would anyone happen to have an extra one of them plastic pieces for the top of the shift boot?
- VAG in San Diego Area
- Those out of warranty, do U still take your car to dealer or a private mechanic for maint/repairs?
- Mechanic Recommendation West Suburbs Chicago
- What kind of oil is recommended for a 97 2.8q ...
- 98 2.8q CEL after spark plug wire problem...
- Which percent tint?
- ECS Tuning has MAF for $46.95. Is this MAF as good as OEM?
- fuel typ? 1.8T Do you have to run super?
- Missing Boost: Installed Samco Turbo Inlet Pipe...
- DEFI Amber Gauges now installed & GIAC 'Beserk' Software Peak Boost Reading
- Seated heats
- Anyone know where to buy H and R race springs?? . . .
- Is it possible to convert the FWD to RWD only ?
- i got a momo e brake, it turns out im gonna need a new leather boot for it to fit perfectly
- Any B5 A4'ers on 24th/west end in Nashville today? Dark color, dark wheels. Anyone?
- my check engine light just lit up on my 01 a4q
- Timing belt replacement question A4 1.8T 98 - 82000 Miles
- Help! Car shakes and check engine light blinking... (more)
- PSA - when replacing the thermostat on the engine, the order is
- Great, my oil cooler seem to be leaking coolant. How hard is it to replace the gasket?
- Could your A4 be rusting B4 your eyes?
- Extended Warranty
- Ok so i'm still modding... ;) just little mods...
- new rotors and pads in and one rotor seems to rub against the
- Nobody can answer this one...?
- way OT, any of you guys know anyone selling a set of M3 wheels
- Attn: Audi enthusiasts - in all honesty...
- question (again) about my ongoing vibration problem...
- check engine light / ignition coil
- if there was an RS4 in your local scrapyard what woul;d you buy off it.
- Installed the HK traffic Pro
- i'm considering buying this vag tool from a user here, SugarRush i think.
- Airbag Light came on
- Sub Enclosure
- 2.0L or just rebuild 1.8L
- Camber problems
- any DIY write ups for tranny and diff. fluid changes for MY00 1.8tq?
- new best time last night at the drags
- X post from B6..................
- WJM gets excited for the dyno.
- Anyone interested in a Eurocode test pipe. In the classifieds.
- Crazy TCU problem, come wrack your brain and help me (long).
- block
- Computer parts up the wahoo!
- How hard is changing the timing belt, really?
- Not sure if I have a bad wheel bearing...
- Pics of painted door handles (interior) and gear shift surround? (Already STFA)
- My Audi has a new friend
- Samco hoses with APR S3? Anyone else get one lookin' like this?
- Finishing my waterpump install..took the old pump out-->
- Want to install Racing seats
- paging quattrofrog
- should I buy these?
- Reference Needed for Mechanic In San Diego
- Rear brake change on my '96 A4 2.8 Quattro.. Help!
- Will these fit me?
- ok...car is not starting...its the battery...opinions..
- my car has been in the shop for three months now...
- carbon buildup and cyl. 2 misfires
- does anyone near Glassboro NJ have a jack I can borrow?
- How i can make A4 B5 1.8 (125ps) -> 1.8T ( ? ) ??
- first time a4 owner in the dark
- can I use a SPEC clutch and an OEM flywheel?
- Late Nighters..I need your opinion on a purchase
- Horrible surging at constant throttle...help...
- just bought an 01 a4t. the guy said he put in an apr chip, how can i check if its really there?
- Catastrophic Event last night....Fan Clutch failure. Has this happened to anone???
- What's the oil change interval on a 1.8T B5 according to the manual?
- Since we are on the topic of stage III
- think my a/c compressor is toast. anyone replace one? should I just remove it to save weight?
- Rear subframe cracked....Help!
- Why did I get a test pipe with my APR stage 3? Isn't it supposed to come with a cat?
- Why can't I hear my turbo spool up?
- Any know have experience with strat. car cover?
- does anyone know what front lip this is?
- Has anyone tried the Dunlop SP Super Sport Race tire? ....
- I know it's a tiptronic but my '99 1.8t avant w/chip is a dawg going 0-20! what can I do? anything?
- APR B6 stage1+ 235hp/275lb-ft? That is pretty impressive on k03...
- Dead pixel line in trip computer... will it get worse? Any fixes?
- ACNA Potomac Fall Foliage Fun Run, October 30th!
- This could be news.....
- The winter wheels are here (BWW)
- Gonna change spark plugs myself tomorrow. Do I need any special tools or
- Help with seat...
- Anyone know where i can find a rear bumper , inexpensive ;)
- Any guesses as to what APR is going to release today?
- new sig?
- lose creaking driver seat....covered by warranty?
- confirm brake bulb part number?
- Hit or Skip? Go fast bits hybrid recirculating bov
- Audi 1.8i 1996 A4
- DIY Intake
- Woot! Woot! Woot! APR stage 3 arrived today!
- In my continuing effort to convince the wife to chip...
- please help !!
- 2000 A4q Armrest Lid Removal - Please Help : )
- which is spark plug 1?
- has anyone used the powerslot prostop ii rotors (slotted/dimpled)?
- when the car is cold and i'm turning hard (like turning around)
- Is there a temperature sensor in the headliner?
- Help! where can I get some aftermarket wheel studs with smaller heads?
- Catalytic Converter
- who here is in the Pen15 club?
- handling issues? ideas?
- Rain Sensors for B5 Audi
- Repost from last wk: Anyone know who's Silver S4 is on MTV right now? "True life Im rallying to LA"
- RS4 bumpers back in stock. Special Price - $995 shipped
- check out this engine monitoring system...
- is there any part in the engine that can become unbalanced...
- problem
- Starter dead? sound clip included
- Heel and toe problem / question
- '99.5 A4 1.8TQ 5-speed on Ebay
- lucky TT buyers... the 2nd gen TT will bare an AL chassis
- When's the last time YOU changed your microfilter!
- Anyone using Royal Purple Gear Oil...
- i searched extensively...spark plug question......
- what is "hot bolt paste" exactly....
- Air compressor BT: just got one from a friend, a little one (1 gallon), after the compressor......
- cruise control causing erratic idle?? need advise...
- WTF!?
- How can you tell the difference between HID housing and non-HID housing?
- check this out....
- brake booster/vacuum booster (off-topic, non-audi related, just about brakes in general)
- mind if i post a non-audi related question about brakes?
- belly pan and 50,000 mi service?
- Weird...
- Airbag light on...again. Little help please.
- I want the black alcantara shift boot with nogaro blue stitching someone was selling.....
- Dealer says I need new ECM- but I have a chip
- Ronal wheels & Audi Centercaps
- ne1 bought these from this guy??? ne good?
- Anyone polish the cam cover? I just started on my dads and it polishes reallyeasily
- can somebody check a part number for me please?
- Okay, Evap code even after I replaced the gas cap......what next?
- Do dealers keep a worldwide list of what service was done to your car??
- Quarter Mile Simulator
- Do RS4 avant seats fit normal a4 sedan?
- How do you remove the A-Pillar internal trim?
- Maintenance for 2000 1.8TQM
- I hate following pickup trucks...even at 10m distance they still can chip your hood: (
- RS4 conversion in Nevada........
- a4 for a college student?
- Not Audi but still B5. Amazing accident pics!
- Early Christmas...
- Where can I buy those covers or lids on the bumper that's for the headlight washer???
- My first sig., opinions?
- What is wrong with my fuel gauge??
- *stock* 96 bmw 325 vs. 98.5 a4 2.8q
- "knock knock knock" coming intermittantly from RF wheel well during driving...
- DTS and RedLine MT-90
- 2001 1.8T, occasional CEL, car always runs fine, Frickin' annoying...
- Whos wathcing this show on mtv right now?
- How many g's did u invest in modding or fixing your baby
- Time to replace the front wheel bearings (groan), who's done it, and how hard is it?
- Rockguard Or Whatever
- Seriously need help with boost pressure prblm...(long)
- Tuning
- timeslip for anyone who cares
- Need help with engine sound!
- RS4 hood grille, $73. Best deal?
- GB for Carbonio intake? Anyone know of one?
- When BOV's are recirculated, do they still make the BOV sound?
- AH Problem after Problem!
- Clutch Stop Diagram for TANMAN
- WTF?!?!? Went in to disconnect vacuum hose and found the hose was completely severed (sp)!!....
- wow ran a 13.5 @ 102.98 MPH last night.
- Can someone tell me where the 4 8mm mounting bolts are to remove driver side lower dash panel??
- Hooters GTG: Tonight, East Meadow, LI
- To all....I apologize for what happend before....
- A look back to clutch stops...
- How can you tell if you have the HICO/HUCO or Bosch Ignition control unit?
- nitrogen filled tires
- Dealer just finished installed Stage 3 Clutch and LWFW - what should I expect for the first ride ?
- got some props from an a8 guy today on the way home from work
- ***question about engine/tranny or exhaust noise...***
- Coolant leak, can anyone find more info on this "connector" at the back of the head?
- What's the best place to buy FK automotive taillights from? I've seen around $250...anything better?
- Installing the VDO boost guage from APR today, any tips before I start???
- For those who know about chaning bulbs to a higher wattage
- How much boost should you see throughout each gear?
- Found some stuff in the audi bin in my garage..
- What kind of Xenon bulbs are you guys using?
- Reminder: ** NYC Metro Area Audi Group: Cliffs of Insanity 2004: The Revival** is still on!
- VDO Boost gauge install question.
- any suggestion? I need some help 98 2.8 65,000 miles
- Woohoo its done!
- Who here can mod my RS4 knob to display a 5-speed shift pattern? Anyone?
- Anyone seen this Nav system? Says it only costs a few hundred Cdn!
- has APR released their new product for today yet?
- I want the silverstar white bulbs for headlights and the stealth corner signals. Anyone ever get...
- just wondering... anybody selling their c/o's?
- BOV vs. Diverter Valve?
- Some Carbonio numbers. Although, on a stock 1.8T B6.
- I wonder where LLTek will ship my catolog..
- Ok RKA, I snipped off the part near the coilpacks... now how do I get it back on??
- Would the Stock resonator work decent enough on a custom 2 1/2inch Cat back exhaust? its 2 loud!!
- Finally after 4 years of waiting patiently
- Changing spark plugs now...how do you unclip the thing that connects to the coilpack?
- Winter wheel-tire Specials..
- anybody have a spare set of rings i could steal?
- Airbag Control Module Code help
- how hot is this color?
- Couple Ideas
- Oh yeah....got the 2005 Lltek catalog
- Diverter valve questions
- i need a used apr SIII kit right now
- Which body kit is on the Ronal A4 (ronalusa.com)
- Experts Wanted
- What make do you guys think this car is?
- Proper way to bed brakes? I ve heard a ton of diff stuff
- in the market for HPA R32
- Nokian WR for A4
- Motodyne has a new turbosystem out for the A4 1.8t B5s.
- anyone successfully sold a stock exhaust on ebay auction & how much?
- Hey Guys Signal Bulbs
- How much HP will this give me?
- how to check coilpack/ignition amp????
- GO MOTHER F'N SOX!
- how many of us have done a clutch replacement on their own lately
- anyone have a pes t-28 chip for sale?
- Put car up for sale Monday. I will miss if she sells
- where can i find jms side skirts?
- can someone please darken the rims on my car but leaving the chrome around the mag
- "HELP" who know's where I can get hub centric rings for BBS wheels any one know the inner diameter??
- Love the sound of my engine right now
