- CEL help please...weird code
- So last night I realized that alot of the creaking I have goes away if I'm braking
- If one of your B6 or B7 buddies wants help with a coilover install...
- Brake noise = Disintegrated pads
- Practiced welding for awhile yesterday...have been doing stick for a few weeks and tried tig
- vag
- Crappy metal masters off. Axxis ultimates on. MUCH happier. Stopping feels the same but quiet now.
- help with a4 stereo
- Can't decide between these 2 wheels
- Help needed: turning signal not working.
- Looking to do a cheap upgrade/mod to my car (under $50). Any ideas?
- ly7w aerosol and clear coat $35 at expresspaint.com, hit?
- Has anyone been able to log on to www.blauparts.com today?
- OT: I am back in the land of the free, the home of the something..... WildBlue sat. intraweb rocks!!
- Another question: Anyone but JA4T can answer...
- Cleveland Auto Show , 1st car with big grille that I could own
- Is this hole normal? No rubber plug or anything? See pic
- Xpost: Aw, NE Winter pwned me finally *Accident* 6pm tonight
- who has a spare cat laying around.. mine has a hole in it
- Interior Trim.. paint or no paint?
- LED bulbs (exterior) = teh skip.
- Is this what I need to change the transmission fluid?
- 1998 audi a4 2.8
- 245/35 18 tires on 18x8.5 32mm offset???
- Looking for picture of hibiscus red a4 with aluminum polished side mirrors
- RiegerAudiA4 got me searching for some FMIC stuff, whats everyone think of this? crap?
- First oil change with the Fumoto drain valve today and I'm a little disappointed. Slow draining...
- So hypathetically speaking...lets say I were to buy one of those universal piping kits off ebay
- I've got a Sparco steering wheel. Which pins on the OEM connector should I use for the horn?
- I think I broke my DV - plus a bonus broken thingie! Need some input before I drive this 2 hours...
- pics of rims
- WTF??? on oil stick +PIC
- Where can i find an Intake Cam Shaft for a 99.0 1.8 wath an AEB engine?
- Cooling down the engine [OT]
- Followup TB change question, cams wont line up at TDC
- Autodimming and compass mirror resources
- boost gauge prob
- Kamei Grill removal
- This is why you should replace your tie rod end hardware!!!!! Help?
- BSK missed his Weekend MOD thread. What are you guys doing this weekend?
- High miles... High boost?
- HID bulb install... d2s to d2s....nothing fancy....
- Why does edge racing suggest tires that are to small for the rims?
- What to look for when the timing belt fails?
- Anyone in the Dallas/Denton/Plano Texas area with VAG com
- hey just got a question whats the little sensor in the ecu box jw
- Dung Beetle...
- jammed hood, any help?
- Funyuns being onions and fried and not being potatoes or bananas can be called chips too right guys?
- ok need some advice....
- Good price for ignition coils? n e 1 had xperience w/ these?
- Flip Down thing above rearview mirror?
- god damn today was intake day
- Anyone here have the Vogtland Coilovers on their A4?
- STARTER TROUBLES
- radio in 01 A4 Avant 1.8T
- Uncontrolled acceleration!!!!
- I finally got a new CV end to fix my ABS problem
- are cold air intakes bad for 1.8t's???
- Installed autospeed DTS, but stripped some bolts. Searched and found some info about Helicoils?
- neuspeed ecu problem
- RPM drops slowly...
- anyone know what the stock sport struts are, who makes them
- E-codes are here... before I do the install I need to know two things...
- Ok so the whole thing about intakes being bad...When I put mine in I noticed this.
- Why does one noob ask so many questions?
- why is it such a bitch...
- I wonder why we don't get more new guys hanging around here....
- my exhaust vids (x-post from sca)
- wat intakes do u suggest 4 a 2001 2.8qa
- 2000 A4 Quattro.... have to drop the suspension to remove the tank?
- Trying to diagnose a strange noise...passenger suspension, does everything look okay?
- EVOMS air intake?
- sorry for the OT but another Skyline Dyno Near Mishap... I cnat not share it...
- I guess it comes in 3s. snapped lug, found my source of losing coolant was seaping rad, now this:
- anybody know the link to where I can find the VW bug sunglass holder
- Exhaust question...
- will the stock changer work with the NavPlus setup?
- hey 710N users
- woot, woot. I'm home with out a tow. BPV popped off at the IC pipe...
- Help jammed hood from hit and run.
- whoo hooo!!!!
- you 1,8t bastards!... just checked something on my future purchase... the filter
- TROTO i got a question for you
- I really hate when people compare the Audi rings to the Olympic rings...
- CD Changer - Hooking up Panasonic DP600 to concert H/U
- whats the stock exhaust on a 2.8 a4 made out of?
- Last small question, trying to get a t-bol for my TIP...
- Quick question, vac hose size, 3.5mm or 4mm?
- interesting Carputer install posted in the B5 S4 forum. needs a nicer looking face plate, imo
- Battery turns out to be ok according to battery tester. Anyone know what the key off draw should be?
- argh! car took a dump. Good thing I have my vag with me. car went pop, then pisssssssssst
- Ecode Headlight Question : The focal point of the projector beam is pointing towards the
- Any tips for removing C pillar cover? (with airbags)
- there is an 18 CH MTM chipped ecu on ebay
- tiptronic tranny problem...
- Did I get a bum Optima Red Top?
- WTK: anyone have good exp with wheel repair places or anyone has a borbet type e 17" to sell?
- Can anyone post me some dyno graph's? I'm looking for GIAC 1BAR vs. Standard GIAC K04
- srsly, which chip is bettar?
- Please Help - Door handle broke this morning...
- Looking to buy first A4, need advise..
- would you buy tt 180 317cc injectors w/ 20k miles on them for $100?
- LUK Sachs cluthes from Ebay
- ABS control module
- A friend of mine has a '98 A4 2.8Q, is wondering how far it *could* go....
- Need help determining selling price for my car...
- Fog Light Wiring Question
- 96 Check engine lite update & ***Recall Notice ****
- this is perfect for the noobs, found over in the TT forum. Don't ask why I was there bishes!
- Stock injectors are in FPR set at 5bar. Now to get rid of the Red Tops and get 317cc TT's
- 1.8TQ in a '96 A4 shell?
- When using the Motive pressure bleeder for the brakes, does "fill the reservoir" mean "to the top"?
- Boston Area GTG 2/28
- AEB Cam Tensioner Replacement
- How to enter radio code - 1998 A4 Concert Radio
- Changed my oil last night and replaced the filter, I'm giving castrol syn a shot this time
- Is it common for MAF's to go bad? If so post the milage when you replaced the stock MAF.
- Timing Belt Questions--Torque Specs? How much G12+?
- boost guage power tap
- Does anyone know where I can buy a g-analyst? I was just reading through one of my books and they
- In cold weather when I clutch in I get a woosh noise and have no idea what it is. It didnt bother me
- One week to go for Audi Club NW Track day registration @ Portland!
- New car question...
- So I'm thinking of converting all my bulbs (except interior and headlights) to LEDs.
- Need help diagnosing low speed grinding sound... CV joint?
- OK kids...for some of your viewing pleasures...my "cockpit"..lol
- Quick question about 99' 1.8t CL Pump
- VAG help: How would I activate the secondary air pump? I need it to run to diagnose
- question about auto tranny service
- What do you think of using this everytime...
- Just wanted to give a plug to Gavin @ Modulemaster. Got the ABS module back in 30 min ago and
- check engine light
- This is bad for a dyno i think...
- How many of you have a spare ecu and why?
- are you guys here ? .. good job fixing this ;)
- Anybody install a camshaft position sensor??
- Mike@purems quick question for you
- radio not picking up a signal
- Brakes seize after parking car overnite
- Timing belt troubles, TDC marks aren't quite right
- Tire Refinishing CT/NY
- bet it's a fun car either way... and my brakes are squeaking.
- is our exhust 309 stainless or ? thanks
- Yay my test pipe shipped today...and clear sidemarkers yesterday
- common places oil leaks from engine? 97 2.8 qm
- Well I think I just got someone fired...
- How do I remove my steering wheel and what tools do I need?
- OT: For under $80 (assuming using some "free" parts too) how would you build one of these.
- 97 to 01 taillight upgrade...
- Celebrity visit to my dealer today
- Car wont start
- help! check engine light +battery light+stalling
- 1800 $$$$ what do you buy for 18" wheels & tires? thinking sportecs?
- Noticed this crunk on the top of my oil filter yesterday...
- My reply to BSK's question yesterday to Tom at ECS about recent shipping issues:
- It's hard to tell what's wrong with my washer fluid reservoir and why it leaks, but how do i remove
- Paging GTIVR62801 + Audi !
- HELP - 96' Check engine light after battery change
- 96 manual tranny fluid change
- Our new website is up!
- NOOOB question! If dealer takes care of my TB can i hand my tech APR Snub mount and say "here" and
- What's a good engine oil to run at a moderatly cold high elevation?
- What is this?
- Which to get? 1.8T? 2.4? 2.6? 2.8?
- Cool pic taken out at the track...
- Used a Pela 6000 oil extractor last night...worked like a champ
- OT: Thanks for all the great replys yesterday on where you learned, etc...
- Ques for the guy that just bought the HID kit from JAPAN!!!
- $1000 for a timing belt replacement!!??
- 96' a4 2.8 v6
- turbo problems
- Reminder: La Jolla GTG tomorrow night
- noob question, why is the awe pressure tester only listed under s4's.. i need one will it work
- TRE with 121k miles on them are a bitch to get off... lots of torque / PB / and heat and they
- wheel-well extensions - upgrade kit
- Cheapest place to buy front right axle?
- Are Passats known to have timing belt failures??
- Catalyst Warm Up Efficiency Problem
- for running caps where are you guys shifting into 3rd gear at to start around 3800?
- Don't hate me, but I bought Audi Junkie's last Audi...
- I have door panel off and cant find door (open/closed) sensor.Anyone have a pic of it or can explain
- Computer chip
- Pulled up this code: 17746 - camshaft position sensor (G40) open or short to plus
- Changing EGR Valve
- pol(e): how much did you pay for your a4|miles|DOP|what year and options|1.8t or 2.8L?
- audi meets and volks
- Sport Sprins on the bay
- Haha, this kid knows what's up.
- e brake light on
- Changing interior speakers
- ABS and Brake light goes on and off....
- P0116 & P0401
- Engine died while driving, cranks but no start
- Error Light
- Quick poll: whats the next mod that will be done to your car?
- little ot, need AW opinion
- Guess that Audi part!, Warning large pic.
- GD it! I have another boost leak! Grr, where is it this time...
- I searched, boost problems...
- Where can i find a set of cheap smoked tails?
- Question on used 2.8L transmission prices...
- So I got tired of the weak battery. Went looking for the Optima with reversed terminals. First off
- Brake problems.
- How to make your driveline stabilizer better. (link inside)
- Startup noise - Help! Service question too
- ways to fix an oil leak? 97 2.8q
- yeah for audizine!
- Difference between ATW and AWM engines?
- A Ferrari is snapped in two
- a4/s4 suspension
- Quad turbo........Who has the gonads to try this?
- Having a couple issues...the voltage meter on my car has recently been closer to 16. Not at 16, but
- $$stuff for sale$ Two timing belt kits!!
- Needs more boost
- Those who have pulled BOTH their headlights on a 2000 A4, how long did it take u the first time?
- A4 engine swap
- Brake Line
- New York City -- Shops
- A4 is hard to start....
- Drive Las Vegas Speedway, 4/28-29
- Ronal sale ends 2/24
- Follow up question - is it worth getting a manual?
- pitures of my wifes Avant. She was doing donuts in about 6-8 inches of snow. we love this car!
- Longevity of a 1.8t A4
- Replaced the thermostat after constant misfires
- wheel bearing
- How did YOU learn to fix your car?
- Just wanted to thank all of you for your mature behaivor yesterday while I was away..
- Fricken Crap, Got another CEL..I need a vag. this is ridiculous...
- before i get my TP in, i did a few quarter miles with my Passport G-Meter
- non n00b n00b shout out
- Who knows what to look for in a micrometer?
- looks like a mod decided to show up
- Weird Noise
- Any idea if the ABS modules on A4's are the same or do they vary with the year/model
- B6'er here asking a question: Who here has a PES G2 SC for their 2.8?
- Odyssey 925?
- Is there modification involved in putting s4 power front seats in a 1.8t?
- 1999.5 strange blinker problem
- Can anybody help me? Tons of misfires
- slightly OT (what isnt OT today) porsche burnout
- how often do you check your local craigslist? there is a ton of stuff to grab
- has anyone tried extending remote range by making a bigger internal antenna in the remote?
- Question about 1999 keyless entry replacement
- wtf!? is this the b5 forum or awot forum!?
- Here's a pic of my dog
- 18 x 8.5 BBS RX II wheels for sale in the classifieds
- Since there are no mods, here's some Deutschland nastalgia for ya
